850ford 3 #1 Posted November 29, 2020 I have a C161 with a 16hp Kohler in need of a rebuild.(burning alot of oil).Can anyone recommend someone in the Massachusetts area? Thanks Share this post Link to post Share on other sites
ebinmaine 70,719 #2 Posted November 29, 2020 Where in Mass? @diesel cowboycowboy @wallfish @JCM Share this post Link to post Share on other sites
wallfish 17,491 #3 Posted November 29, 2020 There's a guy on Worcester CL that advertises about repairing vintage equipment and also does Kohler rebuilds. He's in BoyIston. I have no experience with the guy but you can contact him through the CL link below https://worcester.craigslist.org/grd/d/boylston-gravely-tractor-service-and/7219283355.html 3 Share this post Link to post Share on other sites
diesel cowboy 263 #4 Posted November 30, 2020 I'm in Templeton and can rebuild them. Unfortunately at this point I'm so far behind with jobs I've got in the shop right now if I had it at work it would probably be at least the end of December before I could even think about looking at it though. 3 Share this post Link to post Share on other sites
ebinmaine 70,719 #5 Posted November 30, 2020 6 hours ago, diesel cowboy said: I'm in Templeton and can rebuild them. Unfortunately at this point I'm so far behind with jobs I've got in the shop right now if I had it at work it would probably be at least the end of December before I could even think about looking at it though. Given what I know about the conditions here in Maine that's actually not a bad wait time at all. 1 Share this post Link to post Share on other sites
Ro-Go 76 #6 Posted December 2, 2020 Looks like I'm in this camp too. Anybody in the corridor from Eastern PA to Western MA? Share this post Link to post Share on other sites
953 nut 57,891 #7 Posted December 2, 2020 11 hours ago, Ro-Go said: Anybody in the corridor from Eastern PA to Western MA? I had a Kohler bored by Northeast Automotive and they do Kohler rebuilds. They are in Nassau NY, 5184882715, ask for Garrett. They are good people, very honest. 2 Share this post Link to post Share on other sites
richmondred01 2,288 #8 Posted December 2, 2020 (edited) I rebuild them and I currently have none in the shop. Typically a 10 day turnaround. k161, K181, K241, K301, K321 and K341 cast iron kohler engine for 275.00 plus parts and machine work if required. In most cases cylinder will be bored, crank will be ground, valve seats ground or reconditioned. New piston, new rings, new rod, valves new or reconditioned, all new seals and gaskets. In some cases valve guides and bearings are replaced. Entire engine brought back to factory spec. I no longer do performance/pulling engines or twins. Once rebuilt, and properly maintained, it will give you another 30-40 years of service. I don't cut corners, I take my time and get it right. 40 plus years of working on and rebuilding k series engines. Edited December 2, 2020 by richmondred01 5 1 1 Share this post Link to post Share on other sites
DennisThornton 4,771 #9 Posted December 2, 2020 36 minutes ago, richmondred01 said: I rebuild them and I currently have none in the shop. Typically a 10 day turnaround. k161, K181, K241, K301, K321 and K341 cast iron kohler engine for 275.00 plus parts and machine work if required. In most cases cylinder will be bored, crank will be ground, valve seats ground or reconditioned. New piston, new rings, new rod, valves new or reconditioned, all new seals and gaskets. In some cases valve guides and bearings are replaced. Entire engine brought back to factory spec. I no longer do performance/pulling engines or twins. Once rebuilt, and properly maintained, it will give you another 30-40 years of service. I don't cut corners, I take my time and get it right. 40 plus years of working on and rebuilding k series engines. Approx cost for a complete rebuild including boring, grinding and new parts? 1 Share this post Link to post Share on other sites
steelman 252 #10 Posted December 3, 2020 11 hours ago, richmondred01 said: I don't cut corners, I take my time and get it right. 40 plus years of working on and rebuilding k series engines. I sure wish you were closer and/or I had your skills! 1 Share this post Link to post Share on other sites
richmondred01 2,288 #11 Posted December 3, 2020 10 hours ago, DennisThornton said: Approx cost for a complete rebuild including boring, grinding and new parts? In most cases, out the door, with machine work, new parts and labor 575-650. 2 Share this post Link to post Share on other sites
DennisThornton 4,771 #12 Posted December 3, 2020 2 minutes ago, richmondred01 said: In most cases, out the door, with machine work, new parts and labor 575-650. I think that would be very helpful to know for anyone considering your services. Thank you! 1 Share this post Link to post Share on other sites
rjg854 11,879 #13 Posted December 3, 2020 17 hours ago, richmondred01 said: I don't cut corners, I take my time and get it right. 40 plus years of working on and rebuilding k series engines. Does a great job too, I have a 16 he rebuilt, and couldn't be happier with it. 3 Share this post Link to post Share on other sites
Gregor 4,847 #14 Posted December 9, 2020 On 12/2/2020 at 9:35 PM, richmondred01 said: In most cases, out the door, with machine work, new parts and labor 575-650. That is a fantastic price. A few years ago, I could have shipped my K321 to you, ship it back, and still would have saved $500 1 Share this post Link to post Share on other sites
