Horse Newbie 7,075 #51 Posted November 29, 2020 (edited) 7 hours ago, WVHillbilly520H said: Yes the quick stop is normal (really hard to get used to after a gear drive before) but 22years I have gotten so used it that I hardly ever use the broke pedal. Also the full mark on my dip sticks of my 520s is what I go by and as long as it is in the cross hatch its good to go, just like an auto trans add only 1 PINT when at the bottom of the marks. 7 hours ago, lynnmor said: I think that each Eaton 1100 has its own personality, some have a rather crisp response when the motion lever is moved and others are a bit soft or lazy. Some will pee during storage and some will be dry. I believe that some drain back a bit while others maintain the level when stored. I do think it is best to keep the oil level a bit below the maximum line. Thanks. @WVHillbilly520H and @lynnmor I have learned a lot from you guys, and all the others, @953 nut, @gwest_ca, @ebinmaine, @squonk, @Maynard, @JohnD, and more. I can count on you all to have the patience, knowledge, and skills to help me keep in the saddle. I helped my neighbor build shelves and a workbench in his Deere stand today, so tomorrow I'll probably look at cleaning, flattening, adjusting, and NOT lubricating the eccentric nut on my motion control linkage. Edited November 29, 2020 by Horse Newbie 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,075 #52 Posted November 29, 2020 Thanks @WVHillbilly520H and @lynnmor. And all the others, @953 nut, @squonk, @ebinmaine, @Maynard, @gwest_ca, @onanparts.com, @JohnD. I really do count on you guys. You never fail to lend a hand. Helped my neighbor build a work bench and shelves in his Deere stand today, but tomorrow I hope to clean, flatten/ file, and adjust the eccentric nut on my hydro linkage. Tim (Horse Newbie) Share this post Link to post Share on other sites
Horse Newbie 7,075 #53 Posted November 29, 2020 Thanks @WVHillbilly520H and @lynnmor. And all the others, @953 nut, @squonk, @ebinmaine, @Maynard, @gwest_ca, @onanparts.com, @JohnD. I really do count on you guys. You never fail to lend a hand. Helped my neighbor build a work bench and shelves in his Deere stand today, but tomorrow I hope to clean, flatten/ file, and adjust the eccentric nut on my hydro linkage. Tim (Horse Newbie) Share this post Link to post Share on other sites
Horse Newbie 7,075 #54 Posted November 29, 2020 How did this happen ?...I don't drink anymore... Share this post Link to post Share on other sites
