Horse Newbie
520H won't move after oil change
Horse Newbie
7 hours ago, WVHillbilly520H said:
Yes the quick stop is normal (really hard to get used to after a gear drive before) but 22years I have gotten so used it that I hardly ever use the broke pedal.   Also the full mark on my dip sticks of my 520s is what I go by and as long as it is in the cross hatch its good to go, just like an auto trans add only 1 PINT when at the bottom of the marks.
7 hours ago, lynnmor said:
I think that each Eaton 1100 has its own personality, some have a rather crisp response when the motion lever is moved and others are a bit soft or lazy.  Some will pee during storage and some will be dry.  I believe that some drain back a bit while others maintain the level when stored.  I do think it is best to keep the oil level a bit below the maximum line.
Thanks.  @WVHillbilly520H   and  @lynnmor
I have learned a lot from you guys, and all the others, @953 nut, @gwest_ca, @ebinmaine, @squonk, @Maynard, @JohnD, and more.
I can count on you all to have the patience, knowledge, and skills to help me keep in the saddle.
I helped my neighbor build shelves and a workbench in his Deere stand today, so tomorrow I'll probably look at cleaning, flattening, adjusting, and NOT lubricating the eccentric nut on my motion control linkage.
:handgestures-thumbupright:
Edited by Horse Newbie
Horse Newbie
Thanks @WVHillbilly520H and @lynnmor.
And all the others, @953 nut, @squonk, @ebinmaine, @Maynard, @gwest_ca, @onanparts.com, @JohnD.
I really do count on you guys. You never fail to lend a hand.
Helped my neighbor build a work bench and shelves in his Deere stand today, but tomorrow I hope to clean, flatten/ file, and adjust the eccentric nut on my hydro linkage.
Tim (Horse Newbie)
Horse Newbie
Tim (Horse Newbie)
Horse Newbie
How did this happen ?...I don't drink anymore...:P
