![Zeek](https://www.wheelhorseforum.com/uploads/profile/photo-thumb-3784.jpg)
Similar Content
By BEN LORUSSO
Hi , im new to this forum. I have two wheel horses that im always fooling around with and joined to get more involved. I have a 520-h and a 310-8 my current project is making up a cat 0 three point hittch for the 520 i was wondering if anyone else has attempted to make one. its almost finished I just have to figure out a way to lift it. i made a linkage out of flat stock that goes to the lift cylender for the attachments I just have to make a shaft for the lift arms abd have to figure out lift links aby ideas?
By Rob R
Hi fellow Wheelers I just completed the fabrication of a Three Point Hitch for my 70"s GT14. Parts List include:
1. Used Wheel horse Rear Axle Bracket to which I added two Class One Hitch Pins with a steel bar welded across (bar was from an old shaft from a bad shock absorber)
2. Lower lift and Center lift bars and center lift arm (purchase from e-bay for $150) Note: One side was adjustable and the other solid, I changed the solid one so that is also adjust so that I could obviously adjust it and also make it fit better by removing a section and welding-in two threaded bolts
3. A twenty inch Class One tow bar from Tractor Supply for $139
Think you'll agree it came-out pretty good. Comments or suggestion appreciated
As a side note might someone know what the rear pulley on the GT14 is for..... I assume perhaps the rototiller... but it looks so flimsy for that? Thanks
