dmhill 43 #1 Posted November 15, 2020 (edited) Does anyone have a C-160 throttle cable and handle they would part with? Edited November 18, 2020 by dmhill Share this post Link to post Share on other sites
ebinmaine 69,707 #2 Posted November 15, 2020 Check with Lincoln at A to Z tractor in PA. New cables can be had from pzep.biz. Not sure if they have a knob. Share this post Link to post Share on other sites
dmhill 43 #3 Posted November 15, 2020 Ok, thank you. Share this post Link to post Share on other sites
daveoman1966 3,768 #4 Posted November 15, 2020 I hav the CABLE and the KNOB... $30 SHIPPED Paypal Cable is in the garage...here is knob / 'T' Handle...not cracked Share this post Link to post Share on other sites
peter lena 8,970 #5 Posted November 16, 2020 dmhill , take advantage of new cabling and control , thoroughly lubricate it first and verify cable end drip with lube , also add more cable clamps to your set up, like these, https://www.amazon.com/Sellerocity-Throttle-Equipment-Compressor-Universal/dp/B07QY5KKJD/ref=sr_1_9?dchild=1&keywords=throttle+cable+clamps&qid=1605534620&sr=8-9 this is only an example , also available at your local h/w store in the small pull out drawer section . when securely mounted and lubricated those choke and throttle controls should work with total ease. do not be afraid to improve an existing set up , pete 1 Share this post Link to post Share on other sites
dmhill 43 #6 Posted November 16, 2020 Thank you for the advice! 1 Share this post Link to post Share on other sites
