lynnmor
Fuel Tank Sending Unit
lynnmor
I replaced my faulty sending unit with a Dorman 55818 in a 520H.  The resistance specs are slightly different, but the unit can be used as is.  By filing a small amount off the stops, I was able to fine tune the sending unit to the gauge.  Be sure to look inside the tank and check for clearance between the float and the petcock screen, you might have to tweak the float arm just a bit.  I made short pigtails with the proper ends to complete the wiring
  • Like 5
gwest_ca
Good post. Copied your info to here
Garry
cleat
Did the sending unit holes all line up to the tank top mount ?
Thank you.
