johnnymag3
Best way to remove older decals
johnnymag3
Looking for the best way to remove old decals without hurting the paint. Have never taken them off, but its time to give the 1257 a new set...
thanks, John
WHNJ701
Heat gun, or oven cleaner
johnnymag3
I do not want to hurt the paint....will oven cleaner destroy the paint Jason??
Edited by johnnymag3
Achto
Hair dryer or heat gun will aid in removal. A gum eraser wheel on a drill is the best way to remove old decals and glue residue without damaging the paint. I prefer a 3M brand one but here is a more economical one.
https://www.amazon.com/VViViD-Diameter-Remover-Including-Adapter/dp/B084D43QF7/ref=pd_sbs_263_27?_encoding=UTF8&pd_rd_i=B084D43QF7&pd_rd_r=d3801901-1002-4472-a639-f85909d705ab&pd_rd_w=n5dgy&pd_rd_wg=a7VS1&pf_rd_p=ff9b5089-1414-4e8f-9675-3397e98bf276&pf_rd_r=41EZYMFZXG4HR82F3F6Q&psc=1&refRID=41EZYMFZXG4HR82F3F6Q
  • Like 5
  • Thanks 2
Pullstart
If you heat the backside of the panel too, it heats the glue before the decal.  More likely to separate right the first time :handgestures-thumbupright:
  • Like 4
peter lena
In addition to the heat gun, a fresh  industrial razor blade, one sided ,in the holder will start the edging for a possible peel off, pete
Vinylguy
Heat gun plastic razor blade. heat and peel slowly heating as you peel.
the original decals have been on for 50 years. The slower you peel the less adhesive residue remains on the paint.
oven cleaner is a last resort as it can and will harm paint if it is on too long.
Edited by Vinylguy
  • Excellent 3
Vinylguy
As Pullstart said. Heat the backside of the panel first to soften glue then heat the decal left or right end edge and lift with plastic blade.
Achto
A little how to for those who have never used a gum wheel to remove decals.
  • Like 4
squonk
I 2nd the gum wheel
Zeek
 What he said :D:dance: I use Xylene to remove residue without harming paint. You can get it at box stores.
Edited by Zeek
rmaynard
I agree with the heat and plastic scraper. But I get the rest of the glue off with VM&P Naptha.
rjg854
WD40 works pretty good on glue residue, also
  • Heart 1
DennisThornton
I always used heat but as I was going out of the repair business 3M was offering their removal wheel.  I've never used it but gathered it worked well.  Glad to here it does.
