Oldskool
Project "Snow Drift"
ebinmaine
Like that "6 Volt"...
DennisThornton
image.jpeg.6503224b6ad42dea29077111b234aaf9.jpegimage.jpeg.6503224b6ad42dea29077111b234aaf9.jpegMV Air Cleaner Service - Military Trader/Vehicles
  • Like 5
DennisThornton
Camo chains!  See thru chains?  Glass chains?  Invisible chains?
Other than that...
WOW!
  • Haha 3
Oldskool
Other than that...
WOW!
I still have to preload the rear bearing sets before the chains. But getting really really close now.
lynnmor
If you have the type of Briggs that blows head gaskets, re-torgue the head bolts after a few warmups.   They blow because or the wide spacing of head bolts where the valve train and cylinder bore are close.
Name:  IMG_20140704_201523_768.jpg Views: 7842 Size:  27.3 KB
Oldskool
I do, and that is where it failed. A poor design.
Oldskool
Looking like a foot of snow for Monday night into Tuesday. It could be some sticky stuff. A good test track for the Y.E.T.I. ?
  • Heart 1
wallfish
Absolutely!!!!!!!!!!!!!!!!
Are you going to be ready?
Oldskool
I'm going to shoot for Thursday now. Its going go be low 30s and sunny then. I have to get my generator going and my plow truck to be ready for this one. I've kinda been slacking on that dept. The most snow we have had all winter here  was about 4in.
wallfish
That other stuff isn't important! Stop screwing around so you can screw around:ychain:.
  • Haha 2
Oldskool
Really , I will be ready for Thursday. I'll pull a couple of all nighters if I have to lol
  • Heart 1
wallfish
Just bust'n some balls. Looking forward to whenever you get'er going.
(and some new art work on the chalkboard in the background)
  • Haha 2
Oldskool
When you just cant reach where that hood hinge bushing is supposed to go.
Oldskool
LOL ya it's about time I erased that turkey from the board
Oldskool
Looky GT tracks.  Single digits, minus digits with the windchill for the last few days. The poor thing has been outside under a tarp. BUT it's the only worker that started and ran. Stepped up to the plate and moved everything I needed moved before the snow storm. Including one of the 4 wheelers that wouldnt start. Wahoo more garage time.
  • Like 5
wallfish
Very envious of this! I haven't had any fun garage time for waaaaaay too long. 4 years or maybe more.
Oldskool
Holy cow. Well get out there lol
wallfish
Working 7 days a week doesn't leave much time. Sunday is partial screw off day getting parts and materials for the week but extra available time is spent on maintenance stuff. Like fooling around AGAIN with that dam 520 hydro linkage. It changes it's mind by the temperature outside. Worked perfectly fine when I went through it all in the fall but now that it's 2 degrees, Surprise! And then a front tire decides to slow leak this week too. Without a belt release, it will harder start in the freezing temps because it's constantly turning the trans pump. Give me a gear jammer any day! LoL
Oldskool
Ya that does make it a bit tough.  Someday there will be fun garage time
Oldskool
I know custom stuff has its hitches, but why a throttle cable? Something as simple as that. It was working fine on the first test run. Now its binding up. I have run and rerun this cable. There doesnt seem to be a sweet spot. It's a new cable, and the linkage on the engine moves freely. No matter how soft of a swoop I put in it, it binds up. I would love to move on but its driving me batty.
  • Sad 2
wallfish
I'm working on it. LoL
Sometimes if the Z bend is twisting the wire it can bind more easily. Re-make the Z ?
A small kink in the wire inside the conduit can cause quite a bit of friction.
Something not lined up at the lever end maybe?
If all else fails maybe a lever to transition between the cable and the carb ?
Just throwing stuff against the wall again
Oldskool
I did remake the z.
It may have a kink, but when its unhooked it moves as slick as snot.
It's fairly straight on. I've seen worse.
Right now I am trying to figure out a linkage, but a have clearance and exposure issues.
Keep throwing lol
wallfish
  On 1/31/2021 at 11:34 PM, Oldskool said:
Keep throwing
Rusty wire causing more friction inside the conduit when it's bent?
Governor spring too stiff of a tension?
We tied a string for the throttle on a go kart when we were kids! It was direct to the carb because we didn't understand there was a governor or how that worked. Only thing we knew was pulling on that string made it go faster than if you didn't. Woooo Hoooo  One thing for sure though, that setup was dependable!
Same as jamming a quarter in a centrifugal clutch. We didn't understand how that worked either but doing it made that mini bike go faster. Harder to stop the thing but stopping good was never really the goal. LoL
  • Haha 1
Oldskool
Its brand new so I dont think rust is an issue. The governor linkage moves smooth and no extra friction.
Never heard of the quarter in a clutch before.
  • Similar Content
    • Oldskool
      By Oldskool
      Hey guys I have been given a box of these flap wheels.
      5.25" x 1.5" with a 1" arbor hole.
      I instantly thought great I can put one on my bench grinder.
      Nope!    Not that simple.
      The arbor size is different, and it's to wide to fit inside the the guard.
      I thought of removing the guard but would like to have it there.
      I guess I could make an arbor adapter and a spacer for the guard,and a new tool rest,etc. More time involved then first thought.
      Does anyone use these, and if so what do you have it on?
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      I've had some stuff laying around for a while now. I've had some ideas kicking around my head for a while as well.
      Well they met each other a few days ago.
      This is going to be a camp buggy of sorts.
      Like any of my other builds I would appreciate any input anyone want to donate.
      The base is an 1982-88 Yamaha G1 golf cart.
    • Oldskool
      By Oldskool
      Can anyone ID this?
