Oldskool
Project "Snow Drift"
Oldskool
As I've been looking things over this morning I think I need some sort of retrieval point/s. No ideas yet.
ebinmaine
And we talking like hooks and shackle type stuff?
Oldskool
Ya something like that
ebinmaine
I certainly agree that would be a good idea.
My first thought would be to make sure if at all possible... That you have a mounting point that won't be caught in a pivot or drive line.
In the front perhaps hanging down in the middle from behind the pivot or directly to the front of it if you have room. In the back I'm not so sure.
Oldskool
The front will be easier then the back. Its something I should deal with fairly soon before I have to much stuff in the way.
ebinmaine
Forgive my memory here but do you have any kind of a toolbox built-in? It probably would be a stellar idea to keep 6 ft or whatever of SOFT strap or thick rope to be wrapped around whatever components of that machine need to be pulled upon.
Oldskool
I do not have a toolbox at the moment.  I will probably just have a gunny sack on the rear rack. I really doubt I will be any more then a 5 min walk from my truck or garage at any point of use.
SylvanLakeWH
Simple eye hook on front and back, low, should do the trick... rolled up jerk strap will address connection and flexibility...
:twocents-02cents:
Oldskool
:twocents-02cents:
The front is in production now. It's quite military looking
  • Excellent 2
ebinmaine
45 minutes ago, SylvanLakeWH said:
jerk strap
Not very nice of you to call me names
  • Haha 4
Oldskool
Again something simple, but sometimes that's all you need. The collar in the middle of the shackle is plug welded to the shaft to keep it centered.
  • Excellent 8
Tractorhead
That‘s really cool, so you can built a backhoe on the back of a Horse and maybe lift it onto the Trailer.
Edited by Tractorhead
  • Excellent 2
Stormin
I suggest one on the rear as well. Just in case you can't pull forward.
 If the jerk strap referred too is a kinetic rope, you need to be very carefull using those. Don't jerk them. Just gentle pull.
Oldskool
Backhoe may be this spring lol
  • Haha 1
ebinmaine
We s'pose that'd be a "kinetic" strap?
ebinmaine
Oh Man.....
  • Haha 1
Oldskool
I've been walking by the chassis all day trying to figure out where,how, and what design for the back. I think I need to get more assembled to see what room is available.. As far as the jerk strap goes, Ive always just used an old tire between to chains to add some give.
Oldskool
Just now, ebinmaine said:
Oh Man.....
Remember I have the back half from a Haxco Heavy G I picked up with a backhoe on it. The bucket holds just about the same amount as a 5gal pail
  • Haha 1
ebinmaine
Sure would be nice hangin' off a GT14 or something...
  • Excellent 2
Oldskool
It would, but there is enough of the Haxco as it sits to bring it back to life.
  • Excellent 2
Oldskool
A little donation from the local military guy. Now I have a tail light and it's a matching style to the headlights.
  • Excellent 3
Oldskool
The rear hitch point is done. What a p.i.t.a. I had to partially assemble to see how much room I had then dissemble to the point of taking the rear strut section off. I think I can keep moving forward from here.
  • Excellent 7
Tractorhead
That Taillight looks perfectly fit.
Oldskool
Oh it's going to work great. Its surprising thou, that little bugger weighs all of 5lbs maybe a bit more. Wouldnt want to drop it on my toe.
71_Bronco
Wait, wouldn't it be better to have pull points on the sides? So when you pull, the rollers will act as wheels?
If you pull from the front or back, won't the screws be fighting you the whole time?
Just a thought.
  • Similar Content
    • Oldskool
      By Oldskool
      Hey guys I have been given a box of these flap wheels.
      5.25" x 1.5" with a 1" arbor hole.
      I instantly thought great I can put one on my bench grinder.
      Nope!    Not that simple.
      The arbor size is different, and it's to wide to fit inside the the guard.
      I thought of removing the guard but would like to have it there.
      I guess I could make an arbor adapter and a spacer for the guard,and a new tool rest,etc. More time involved then first thought.
      Does anyone use these, and if so what do you have it on?
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      I've had some stuff laying around for a while now. I've had some ideas kicking around my head for a while as well.
      Well they met each other a few days ago.
      This is going to be a camp buggy of sorts.
      Like any of my other builds I would appreciate any input anyone want to donate.
      The base is an 1982-88 Yamaha G1 golf cart.
    • Oldskool
      By Oldskool
      Can anyone ID this?
