Oldskool
Project "Snow Drift"
DennisThornton
22 minutes ago, Oldskool said:
The weak spots are the keyways and the universal joints at the back of the tanks
Hard for me to estimate the forces on those screws and under different conditions.
Fingers crossed!
71_Bronco
By the way, how close were we on our helix length calculations? :dance:
8ntruck
1 hour ago, Oldskool said:
5ft wide 6-/2ft long. My trailer is 5-1 wide 8 long. Should just fit
How are you going to get it on abd off of the trailer?  Special ramps with cleats for the screws to grab?  Load/unload by crabbing sideways on ramps?
Oldskool
It has a full width fold down ramp. Go fast?    🤣🤣🤔🤔🤔 Not sure but I'll try.
ebinmaine
Video Mike. We need video.
  • Excellent 3
  • Haha 1
Oldskool
Soon, soon
  • Thanks 2
Oldskool
What is the width of the woodruff key used on the rear hubs of the bigger tractors?
ebinmaine
@pfrederi
Paul what were those ones you sent me for Colossus?... fit gt14 I think.....?
Oldskool
The reason I was previously asking about the width of the woodruff key was to get a reference of width to the 1/4" key stock I'm using on the universal joints. I'm pondering the idea of drilling/tapping 180 degree from the original 1/4" set screw and adding a set bolt. I may be over thinking it a bit considering my drive unit sprockets have 3/16" key stock. Although they are half again as long. So I dont know. I think I'm just trying to cover all the bases now not as a repair later. That's enough verbal diarrhea for now.
Handy Don
The gearbox for the sickle mower has both woodruff keyway and setbolt holes on both shafts. I suspect this was, in part, because these went to universal jointed drive and driven shafts in some uses.
Edited by Handy Don
Oldskool
I was looking at that. I think that may be because it has a chance to slide off the shaft if the set screw loosened up. In this instance the screw unit doesnt really have a chance to slide off. I'm more worried it will shear the key off.
SylvanLakeWH
Adding overbuilt redundancy now will most likely benefit you down the road. I’m thinking a whole lot of stress with those screws... go big so it doesn’t even feel the stresses...
:twocents-02cents:
ebinmaine
:twocents-02cents:
Certainly some logic to that.
Oldskool
:twocents-02cents:
True enough. I was just thinking of the ole "a chain is only as strong as its weakest link" which in this case is the drive unit key stock of 3/16. I guess I will probably drill and tap before it's all said and done.
DennisThornton
Nice to have an easy or at least cheap "fuse".  Can't get much cheaper than a key.
Oldskool
Your right there. The big thing is the front axle has to come off if I turn a key on the tank. Well the light bulb in my head just went off. Yup I guess I am gonna add the set screw. It's a p.i.t.a. to get that front end off
Oldskool
I picked this up the other day for free.  I think it fits well. A couple more bars in the middle and good to go. At lunch I took the time to make a list of what's left to do on the Y.E.T.I. I'm down to just 12 things. The light at the end of the tunnel??? Maybe.
  • Excellent 3
Oldskool
Ya that's looking better.
  • Excellent 4
  • Heart 2
DennisThornton
I owned and operated in the shop of an autobody shop for 15 years and got to see a LOT of the results of either thinking about how this vehicle will get repaired or not giving it a lot.  Huge differences.  I still remember shaking my head when working on Chrysler products and later smiling as I worked on Toyotas.
Think now about how you will service and repair.
  • Excellent 3
DennisThornton
Also have to know what size "fuse".  My X-ray vision is failing me...  What are you doing to the shafts?
Oldskool
I have been since I mentioned that the front axle would have to come off to fix a cut key on the tank shaft. I now plan on severing the front at the tape mark and .ake the end bolt on. That way I can service one tank at a time. Going back to the fact it's going to be badged as military, it has to be serviceable in the field. So far you can take this thing apart with a pair of pliers a screwdriver and a 7/16, 1/2 ,9/16 wrench.
  • Excellent 3
Oldskool
It has a 1/4" key and set screw originally I just drilled 180degree from that and added a 3/8 bolt that goes in a dimple in the shaft. That way my weakest link is sprocket related not tank related
ebinmaine
That is AWESOME.
DennisThornton
Obviously a lot of good thinking going into this.  Pick your poison, one you have an antidote for!  Right sized fuse in the right place is great thinking!  Later if that fuse is too small you still have choices.
Pullstart
For that redundant set screw, possibly creating a flat on the shaft would help...
  • Similar Content
    • Oldskool
      By Oldskool
      Hey guys I have been given a box of these flap wheels.
      5.25" x 1.5" with a 1" arbor hole.
      I instantly thought great I can put one on my bench grinder.
      Nope!    Not that simple.
      The arbor size is different, and it's to wide to fit inside the the guard.
      I thought of removing the guard but would like to have it there.
      I guess I could make an arbor adapter and a spacer for the guard,and a new tool rest,etc. More time involved then first thought.
      Does anyone use these, and if so what do you have it on?
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      I've had some stuff laying around for a while now. I've had some ideas kicking around my head for a while as well.
      Well they met each other a few days ago.
      This is going to be a camp buggy of sorts.
      Like any of my other builds I would appreciate any input anyone want to donate.
      The base is an 1982-88 Yamaha G1 golf cart.
    • Oldskool
      By Oldskool
      Can anyone ID this?
