Oldskool
Project "Snow Drift"
ebinmaine
6 hours ago, Handy Don said:
can't get my head around driving something like that
It's a bit odd for sure. I've driven different types of lifts and run cranes that were not controlled the same.
Takes a little getting used to it but you'd be fine.
:handgestures-thumbup:
Oldskool
7 hours ago, Handy Don said:
So two completely separate hydro units. Were they driven by a single "serpentine" belt or does one side have a dual pulley with a separate belt to the other hydro similar to a WH mower deck?
The engine has the double pulley. The pulleys on the hydro units are 1 in differant in hieght
Oldskool
Assuming you are thinking of a linkage that reorients the control movements. :D
Thanks for sharing the progress and the pics.
Yes. I will be using a bell crank on each side
ebinmaine
Really enjoying this build. Very interesting stuff.
Oldskool
Thanks. It will start coming together quicker now I hope
ebinmaine
1 minute ago, Oldskool said:
quicker
In case you hadn't gathered by the speed that I do projects I don't think fast is a huge issue for me. :lol:
  • Haha 3
Stormin
Many a true word spoken in jest. :P
Oldskool
The drive units are in. Now for the engine so I can get the jack shaft built. Next after that will be the linkages.
  • Excellent 5
wallfish
Did mother nature weld those hubs on?
Vertical jack shaft? 2 pulleys on top and one below for the engine?
Edited by wallfish
Oldskool
I'm not sure yet if she has welded them or not. Yes 2 pulleys on top and one on the bottom. I may try and use part of the original engine pulley on the top
Oldskool
Update. Yes! Yes, she did. The puller is still on it. I tightened it up and walked away. Maybe it will pop by tomorrow afternoon
DennisThornton
This is awesome!
wallfish
What are those little sprocket/gear thingys on the opposite side of the shaft for?
Parking brake or something?
20201122_185147.jpg.645c303b0df6e32085a1d397279a556a.jpg.5e58124b6451d5997d456ce0eb8fab1b.jpg
Edited by wallfish
Oldskool
Yes parking brake. I dont think I will be needing those thou. I dont think this thing will just roll away.
  • Haha 1
wallfish
:D
I was just curious.
You could use them to spin a cocktail mixer and an ice cream machine
  • Haha 4
Handy Don
Just what you need on a snow machine!
  • Haha 1
Oldskool
Oddly enough we only make homemade ice cream in the winter....so.....maybe could be a thing.
wallfish
What could be better for the launch party day?
The adults get their Mai Tai, the kids get vanilla, oldsckool says "hold my beer and watch this". :ychain:
Do you think it would crab walk if you reverse one and forward the other?
Edited by wallfish
  • Haha 5
Oldskool
I cant wait till launch day
Oldskool
I believe it might. I will find out for sure
Oldskool
1 jack shaft in the makings
Oldskool
Here is more of my DIY jack shaft kit. Let's see how this turns out
8ntruck
It might, if you park it sideways on a hill.
  • Haha 1
Oldskool
Good point.
ebinmaine
You got any slanted ground up there Mike?
  • Similar Content
    • Oldskool
      By Oldskool
      Hey guys I have been given a box of these flap wheels.
      5.25" x 1.5" with a 1" arbor hole.
      I instantly thought great I can put one on my bench grinder.
      Nope!    Not that simple.
      The arbor size is different, and it's to wide to fit inside the the guard.
      I thought of removing the guard but would like to have it there.
      I guess I could make an arbor adapter and a spacer for the guard,and a new tool rest,etc. More time involved then first thought.
      Does anyone use these, and if so what do you have it on?
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      I've had some stuff laying around for a while now. I've had some ideas kicking around my head for a while as well.
      Well they met each other a few days ago.
      This is going to be a camp buggy of sorts.
      Like any of my other builds I would appreciate any input anyone want to donate.
      The base is an 1982-88 Yamaha G1 golf cart.
    • Oldskool
      By Oldskool
      Can anyone ID this?
