Oldskool
Project "Snow Drift"
ebinmaine
You may very well find that what you end up with is okay because of the slipping that snow is likely to offer.
ebinmaine
2 hours ago, pullstart said:
Does that come with lobstah and buttah?
Depends where you live as you well know.
Out in you plow dogs neck of the woods it might be accompanied by lorbsterr and butterer
  • Haha 1
wallfish
10 hours ago, Oldskool said:
I think the original top speed would be to fast for this build
WHAT????
At least make it go fast enough so your @$$ bites a hole in the seat to help hold you on. My guess is if the spirals are right, that thing should have some pretty good control.
  • Haha 2
Oldskool
1 hour ago, wallfish said:
WHAT????
Kinda like the Ripsaw EV2? Just not on tracks.
Oldskool
It may not look like it but I started cleaning the garage. It occured to me that once the YETI was done I would never get it out. It's not like I could just roll it out. So it was time to shovel a path
8ntruck
What, you are not wanting to be like Leroy Jethro Gibbs building his boat in his basement?
  • Haha 5
ebinmaine
I resemble that remark....
wallfish
Hmmm,
Hydraulic lift used to lower and raise some casters?
A hydraulic motor to spin some acme screws or trailer jacks to raise and lower casters?
Small frame or frames with wheels which you can just screw the machine on and off of?
Jacking it up to put something under and taking it off seems like a real PITA so it won't get used if it's too much work to do that each time.
Oldskool
I have done something like that in the past
Oldskool
14 minutes ago, wallfish said:
Hmmm,
I guess a couple of planks and some pieces of pipe would have worked too
wallfish
Did you just KISS me ? :handgestures-thumbupleft: LoL   (keep it simple stupid)
Pipe is good for going one direction back and forth but casters are cheap to add to the planks to move it any direction. :twocents-02cents:
  • Haha 1
Oldskool
Lmao I think It will have it's own spot in the doorway when done. So I dont think I will need the casters.
Oldskool
Not getting much done on it this week but Sunday I will be hard after it again. Also having a hard time picking the sprockets to buy
ebinmaine
My inclination there would be to slow the machine down at top speed, there by increasing your acceleration.
If you discover that it has plenty of acceleration and you want to go faster you can change the sprockets later and still be able to drive it.
If you lean the other way it would be difficult to drive with a lack of acceleration if you don't have enough power.
ebinmaine
Have you started laying out the plans for a 62-bay garage yet?
  • Haha 2
Oldskool
Not wanting to get a building permit I may have to build 62 single tractor buildings
  • Haha 2
ebinmaine
Just for the record I'm okay with this
  • Haha 2
Oldskool
Actually I'm having trouble finding what I want to buy. I thought of maybe using go cart sprockets but to find the 2 sizes I want with corresponding hubs proves tougher then first thought. I was thinking  60 tooth on the screws and a 40 tooth on the drive units. All the 40 tooth sprockets seem to be aluminum and I cant seem to find the correct hub for them.
Oldskool
Here is one sprocket.
ebinmaine
To get the engine pulley I wanted for the K582 Kohler Engine I had to go to a two-piece design.
Have you tried Surplus Center or McMaster Carr?
Achto
Just wondering if you think that a #40 chain will be heavy enough? Those screws will take more to turn than a set of wheels. I personally would bump up to #50 to drive the screws.
Oldskool
Where did you find yours?
Oldskool
Well I was wondering if that was big enough. I figure there will be a fair amount of torque. Is #50 more like dirt bike/ATV chain?
ebinmaine
Eeesh...
It was either Surplus Center or flea Bay
ebinmaine
Hey what about checking with somebody in the logging industry??
  • Similar Content
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      I've had some stuff laying around for a while now. I've had some ideas kicking around my head for a while as well.
      Well they met each other a few days ago.
      This is going to be a camp buggy of sorts.
      Like any of my other builds I would appreciate any input anyone want to donate.
      The base is an 1982-88 Yamaha G1 golf cart.
    • Oldskool
      By Oldskool
      Can anyone ID this?
    • Oldskool
      By Oldskool
      I started a thread a little while back "Something from Nothing". It has been upgraded to this thread because now I'm building something from something lol. I started with a new frame and strengthened the transaxle mount a bit.
