Oldskool
Project "Snow Drift"
ebinmaine
2 minutes ago, Oldskool said:
No logic on the gray. It was just a color I had first thought of painting it. Till the build progressed and I just cant let it go lol
Sounds good to me.
Have you thought over maybe a gray base with black and other colors for a camo accent?
ebinmaine
Maybe headed up there in the actual poundage but your pounds per square inch is going to be far far lower
Oldskool
2 minutes ago, ebinmaine said:
Sounds good to me.
Picking colors drive me crazy. I had thought gray and black but not in camo. Something else to think over lol
  • Haha 1
Oldskool
Very true. I will be interested in doing the math in the end just for the fun
Oldskool
I may be putting the cart before the horse. Thought I would work on some controls
wallfish
20 hours ago, Oldskool said:
I will make the wife a sulky of sorts if I must lol
It was cut off the day we met
  • Haha 3
Oldskool
Oldskool
Lol
Oldskool
So now there is a seat. I took my first good ride on it tonight (insert varoom varoom engine noise).
  • Haha 1
i believe Henry Ford messed with a screw drive
  • Like 4
  • Excellent 2
Oldskool
I believe it was called the Snow Devil. That actually is the inspiration for this build.
  • Like 4
SylvanLakeWH
Pretty cool!!!
Seat switch, no loose clothing and huge foot rests highly recommended... :auto-ambulance:
ebinmaine
11 minutes ago, SylvanLakeWH said:
Pretty cool!!!
I think we shall find because of the very wide footprint that this machine will be quite stable
SylvanLakeWH
Agree.
I was looking at the pinch point between seat area and rotating screws... wheels take things out the back. Still dangerous but down and out... screws will take things down and in while twisting... just an observation...
Oldskool
27 minutes ago, SylvanLakeWH said:
Agree.
Last night I was actually looking at the same thing. I'm thinking the running boards will extend to the back of the seat when finished
Pullstart
Maybe a JetSki or snowmobile kill switch?  :occasion-clown:
Oldskool
Yes exactly. I may have a trailer break-away type kicking around.
Oldskool
The next big step is to make the rear mounting huds for the drive tubes. This is where I have had several design changes. I think I may have finally settled on one. It has to have some articulation while keeping the drive sprockets in line so not to derailed the chain. It also is fixed to the frame so the tractor half of the unit doesnt just flop over. I will try to sketch it out later and post it. Hoping someone may catch a flaw before its made.
Pullstart
What about those three pronged rubber couplers on, say, a hydraulic pump for a wood splitter?  Would they allow enough movement?
what are the screws being made from?
Oldskool
A Lovejoy coupler? I'm thinking PTO yokes like on a dump truck hydraulic pump. The screws are being made from 4, 100lb propane tanks. The paddles construction is still up in the air
Oldskool
12 minutes ago, pullstart said:
  Would they allow enough movment?
They would but there is a length change in the screws while articulating. I would wonder if they would come apart during that.
Pullstart
Heavy spring on the front bearing?
Oldskool
The movement is only about an inch either way of center. My front shaft will slide in the front bearing to compensate for that but the rear joint must stay connected
  • Similar Content
    • Oldskool
      By Oldskool
      Hey guys I have been given a box of these flap wheels.
      5.25" x 1.5" with a 1" arbor hole.
      I instantly thought great I can put one on my bench grinder.
      Nope!    Not that simple.
      The arbor size is different, and it's to wide to fit inside the the guard.
      I thought of removing the guard but would like to have it there.
      I guess I could make an arbor adapter and a spacer for the guard,and a new tool rest,etc. More time involved then first thought.
      Does anyone use these, and if so what do you have it on?
    • c100rider
      By c100rider
      Hello fellas. I bought this 211-3 tractor. I have no clue how this mower deck comes off. I need to fix some areas on the deck, as well as replace a clutch cable. I can't seem to find pictures of a complete deck for this model as it should be. Need help.
    • Oldskool
      By Oldskool
      Let's see your view from your workplace "window". I know some are driving truck,or tractor, work in shops/offices or outdoors. What is it that surrounds you during your work day?
    • Oldskool
      By Oldskool
      I've had some stuff laying around for a while now. I've had some ideas kicking around my head for a while as well.
      Well they met each other a few days ago.
      This is going to be a camp buggy of sorts.
      Like any of my other builds I would appreciate any input anyone want to donate.
      The base is an 1982-88 Yamaha G1 golf cart.
    • Oldskool
      By Oldskool
      Can anyone ID this?
