Gregor
Torquing head bolts
Gregor
I mentioned in another thread that when I went to remove the head from my K321 on the Wheelhorse, some of the head bolts were very loose. I did finally get the head off, and replaced the head gasket. Since both of my Masseys are in the garage, I decided to check the head bolts on them also. WOW  What a surprise. Both are Kohler K321 motors. Both had very loose head bolts. If you have not checked yours in a while, I would urge you to do so. Just my 2 cents worth.  Greg
  • Like 5
WHX??
Best to torque them, get her hot then hit them again. Big blocks I go to 30 then 35 ft lbs.
Thanks for the reminder
  • Like 4
953 nut
:text-yeahthat:    Failure to retorque after a warn-up is an invitation to buy a new head gasket.
The Tuul Crib
:text-yeahthat:
Gregor
I'm glad he mentioned that. Whodaa thunk. I did go back and retorque them, and probably will one more time.
A couple of years ago, I had the head gaskets replaced on my old truck. That's gonna keep me awake tonight. :eusa-think:
Edited by Gregor
  • Haha 1
J854D
Rest easy @Gregor, most gasket companies (like Fel-Pro) offer PermaTorque (no re-torque) head gaskets for automotive & light truck applications. -JD-
WHX??
I recently ripped into this 161 that Pullstart give me. Bet ther ain't but 20 hours on this rebuilt motor. Head bolts seemed to come out easy and the gasket had signs.
  • Sad 1
squonk
I replace head bolts if they are originals. I replaced the head bolts on the original Skonk motor a few years back. 1 bolt broke very easily when removed. I thought oh great this is going to be difficult to get the broken piece out. But  it spun right out by hand. Laying the 2 pieces end to end, I could see that metal was actually missing.
WHX??
You use grade 5s or 8s Squonk?
The Tuul Crib
Myself l would use grade 8 .
squonk
Grade 8 flange head bolts.
pfrederi
 Mike do you reuse the extra thick washers ???
squonk
Yes I do
WVHillbilly520H
3 minutes ago, squonk said:
Yes I do
Do you "descale" and use some type of lubricant? When I built my little SBC,  ARP sent their  "lube in a tube" for the washers before installing the nuts (I studded my heads) or bolts for a more accurate torque.
squonk
Just a dab of oil.
