Pullstart 68,521 #226 Posted August 15, 2022 4 minutes ago, The Freightliner Guy said: Yeah and also how long do you think the tire will last and should I find replacements I bet the tire would be fine if you could get the calcium chloride out of the inside and clean the wheel up, paint it and tube it 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,363 #227 Posted August 15, 2022 (edited) What’s the best way to get the calcium out . And also do the back tires have calcium chloride in them Edited August 15, 2022 by The Freightliner Guy Share this post Link to post Share on other sites
Snoopy11 5,723 #228 Posted August 15, 2022 2 minutes ago, The Freightliner Guy said: What’s the best way to get the calcium out With a straw... it will make your bones good and strong... Don Share this post Link to post Share on other sites
The Freightliner Guy 1,363 #229 Posted August 15, 2022 No not that kind I’m talking about the toxic to swallow kind Share this post Link to post Share on other sites
The Freightliner Guy 1,363 #230 Posted August 15, 2022 I’ll stick to milk and not 60+ year old garbage Share this post Link to post Share on other sites
Snoopy11 5,723 #231 Posted August 15, 2022 2 minutes ago, The Freightliner Guy said: toxic to swallow I KNOW!!! That's the whole point... Don Share this post Link to post Share on other sites
Pullstart 68,521 #232 Posted August 15, 2022 11 minutes ago, The Freightliner Guy said: What’s the best way to get the calcium out . And also do the back tires have calcium chloride in them I’d break the tire down from the wheel and rinse it out good with a garden hose. If you’re worried about waste, I was told once that if you can contain it within a 5 gallon bucket of floor dry, it’s ok to consider it garbage. This was from the environmental engineer safety guy at a large corporation I used to work at. 1 Share this post Link to post Share on other sites
peter lena 9,556 #233 Posted August 15, 2022 @ACman forgot to mention , you were using a dead blow hammer , they were not invented yet in the day , just a regular rubber hammer , did hundreds of tires , just what you did , back in the day of 12 cent fuel oil , I used to drag hose for that , also before SCOVILL ROTARY FUEL VALVES , on the hose . so when you shouted for fuel flow , it would just about pull you off the tank . Saturday was a big day , usually about 150 + call slips on the bench seat, also remember soaking down a German Shepard that charged me as I DRAGED HOSE TO TANK , soaked him down , probably still running , good old days , pete 1 1 Share this post Link to post Share on other sites
Pullstart 68,521 #234 Posted August 15, 2022 (edited) Rear tires are mounted, now for some cleaning, priming and painting! Edited August 15, 2022 by Pullstart Photo 4 1 Share this post Link to post Share on other sites
Pullstart 68,521 #235 Posted August 15, 2022 1-1/2 decks of cards per wheel! 3 1 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,363 #236 Posted August 15, 2022 Does the card trick work better than just taking the rim out and painting it Share this post Link to post Share on other sites
Pullstart 68,521 #237 Posted August 15, 2022 5 minutes ago, The Freightliner Guy said: Does the card trick work better than just taking the rim out and painting it I messed up the paint mounting the tires on the small wheels. I figured I’d save myself the headache and mask off the final product for a good coat on the big wheels. 7 Share this post Link to post Share on other sites
953 nut 63,002 #238 Posted August 15, 2022 9 hours ago, Pullstart said: The cap says “K-28361” though the Google machine came up with little results. Maybe an old parts catalog might help if ever needed. Like you said earlier, sure looks like an engine casting freeze plug. What is the diameter? A polished brass cap would look KOOL! 1 Share this post Link to post Share on other sites
Pullstart 68,521 #239 Posted August 16, 2022 I mentioned that this tractor will be in a parade in town on Saturday. I found out the nieces will be in the parade with us. Well, I built a wheel kit for the snow sled! I need to make the hitch a little more solid and it’ll be in tow behind the Senior this weekend! THE KIDS WILL NOT BE RIDING IN THE SLEIGH ON THE WAY TO TOWN! PNLY DURING THE PARADE! 2 2 Share this post Link to post Share on other sites
The Freightliner Guy 1,363 #240 Posted August 16, 2022 That trailer reminds me of a old snowmobile Share this post Link to post Share on other sites
Pullstart 68,521 #241 Posted August 16, 2022 1 minute ago, The Freightliner Guy said: That trailer reminds me of a old snowmobile That’s what it’s built for… snowmobile trail rides. I took the skis off and added wheels for the summer 2 2 Share this post Link to post Share on other sites
Pullstart 68,521 #242 Posted August 16, 2022 The hitch is complete on the Trail-er-Sled and I built an angle iron draw bar for the Senior too. It should ride pretty level now! 1 1 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,363 #243 Posted August 16, 2022 How much weight can the trailer and hitch handle ? Share this post Link to post Share on other sites
Pullstart 68,521 #244 Posted August 16, 2022 10 minutes ago, The Freightliner Guy said: How much weight can the trailer and hitch handle ? I haven’t broken it yet… most things I build don’t break and that’s engineered enough for me 2 1 Share this post Link to post Share on other sites
Pullstart 68,521 #245 Posted August 16, 2022 Got me a coffee and some wheels to mount on a tractor! 1 Share this post Link to post Share on other sites
Pullstart 68,521 #246 Posted August 16, 2022 @The Freightliner Guy the best card magic trick in the book! 2 1 Share this post Link to post Share on other sites
Pullstart 68,521 #247 Posted August 16, 2022 It floats! 6 1 Share this post Link to post Share on other sites
Pullstart 68,521 #248 Posted August 16, 2022 Soon as this drawbar dries up a bit more, I have a niece on the way to test out the trailer! 1 Share this post Link to post Share on other sites
Pullstart 68,521 #249 Posted August 16, 2022 IMG_6694.MOV 1 2 Share this post Link to post Share on other sites
Pullstart 68,521 #250 Posted August 16, 2022 On 8/9/2022 at 10:50 AM, SylvanLakeWH said: Yes The antique white and the tires separate the reds… I think your pennies were worth it! 1 2 Share this post Link to post Share on other sites
