The Tuul Crib 7,337 #1 Posted October 24, 2020 Since I filled up the transmission on this charger, I noticed there was a small spot on the floor underneath. I had put nearly 5 quarts in it and it wasn't moving yet because the motor was not running. So this would lead me to believe that possibly something to do with the gear case seal? Any ideas? Share this post Link to post Share on other sites
pfrederi 17,866 #2 Posted October 24, 2020 (edited) Re torque all the case and hydro motor bolts... Did you make or buy your gasket??? Edited October 24, 2020 by pfrederi Share this post Link to post Share on other sites
The Tuul Crib 7,337 #3 Posted October 24, 2020 Any torque specs on these bolts? Share this post Link to post Share on other sites
pfrederi 17,866 #4 Posted October 24, 2020 35 if you used GR5 50 if you used GR8 1 Share this post Link to post Share on other sites
ebinmaine 68,343 #5 Posted October 25, 2020 How you doing with this leak Randy? Share this post Link to post Share on other sites
The Tuul Crib 7,337 #6 Posted October 25, 2020 33 minutes ago, ebinmaine said: How you doing with this leak Randy? Haven't got back to it yet. Trying to get my 414 moving so I can do some yardwork. I am going to try and re-torque the bolts and see if that doesn't help. Otherwise I will have to pull off the side of the case to replace the seal. Share this post Link to post Share on other sites
ebinmaine 68,343 #7 Posted October 25, 2020 Just now, The Tuul Crib said: the seal What did you use for a seal? May want to put some time into figuring out the exact location of the leak. White rags or paper towels. Clean it off well then check after (15?) Minutes? Share this post Link to post Share on other sites
The Tuul Crib 7,337 #8 Posted November 15, 2020 (edited) Edited December 6, 2020 by The Tuul Crib 1 Share this post Link to post Share on other sites
