Greentored
Time to build a new trail bomber
ebinmaine
Holy Overdrive Batman!!!
Whatsya pulley sizes there mistah??
  • Haha 1
Greentored
8/4. It’s a little much, will probably drop to a 6 up front. It’ll run a good 5mph in low range 3 haha.
Id leave it and just run in lower gears on trails and save high 3 for the occasional blast, but can’t help but think of that poor input shaft zinging almost 3x the engine speed haha. I want this thing to last!
8ntruck
On 12/19/2020 at 9:30 PM, Greentored said:
Got some bills to pay and need to move some Horse inventory, but raided the parts and made a little progress. Going to run a C gas tank out back in tandem with the B tank.
 No 30mph wheelie machine this time ha, going more for a 15-18mph utility machine. Pretty sure it’s gonna be Kohler powered since I have somehow acquired a stack of K301s.
Since it started as a B100, think I’ll name it the B-1 bomber!
Going to build yourself a bone then.
Greentored
Update: first shakedown woods run!
Greentored
  • Excellent 4
ebinmaine
VERY nice
Greentored
10 hours ago, ebinmaine said:
VERY nice
Thanks buddy! Still plenty to do- theres a lot of masking tape and zip ties holding things they shouldn't ha.
OH- and went to a 5" on the trans, so 8/5- MUCH better. Low range is still relatively 'crawling', and maybe 15-16mph flat out in high. Plenty.
  • Like 4
Greentored
deleted post- wrong thread
Edited by Greentored
AHS
Holy! 15-16 mph! That’s plenty fast for as wide as it is!
ebinmaine
I have a pulley math site saved on the PC.
I need to figure out what to do for Colossus.
I have a 3.5" (I think) engine pulley.
Transmission pulley on it right now is waaaay too small.
Might take some experimentation.
Greentored
1:1 pulley ratio is real nice for a worker and enough speed to have a little fun- maybe 8-9mph with a 23" tire. Thats where I ended up on Hoss (5/5) and really like it!
I scribbled down a quick 'calculator'- if you can decipher this its pretty close.
Divide engine pulley by trans pulley, multiply by engine rpm. This is trans input speed.
Divide that number by 24.6 = axle rpm
Divide that number by 88 (axle rpm required for 6mph)
Multiply that number by 6 = speed
this is for 23" tires. For taller tires, divide by 23, multiply that number by your speed calculation.
Example: 8/5 pulleys on the B-1, 3000 engine rpm (still farting around with governor and throttle).
8/5= 1.6.  x 3000rpm = 4800 input rpm
4800/24.6= 195 axle rpm
195/88 = 2.21
2.21 x 6 = 13.2mph.  The B-1 runs 13mph on phone gps.
Pullstart
Looks like ya found a sapling or four Scott :ROTF:
  • Haha 1
ebinmaine
195/88 = 2.21
If I use that formula I should be around 9 or 10 MPH wide open.
That's plenty fast.
I'll set a minute sometime and figure what's what...
tom2p
my kind of fun !  we did this often at one time
sometimes with a small farm tractor first and me following with a Wheel Horse 704
front part of the 704 hood a little beat up - but took a lickin and kept on tickin !
Greentored
Making my own new trails!   So far I've found 1.5" dia is the 'live sapling cutoff'- anything under, run it down. Anything over, its gonna climb it first, then MAYBE continue over it.:lol:
Brush guard coming next ha.
  • Haha 1
ebinmaine
I like it!!
Pullstart
I think you need an Arsenal of trail bombers... for when Horse Fellers visit!
  • Haha 1
OldWorkHorse
9 hours ago, Greentored said:
More updates:
What is the speed on sumthing like this and pully sizes ur running? I'm building somthing like this and just trying to see what pulleys work well for people.
Greentored
I have an 8 on the engine and 5 on the trans, it runs 16mph on gps with the 26” tires, at 3000 rpms. 7/5 seems to be the standard for the guys trail running Horses. You can run a smaller trans pulley but they can slip if you get into mud or water👍
  • Excellent 3
Greentored
The B-1 went on it’s first group ride on Saturday! Fouled a plug, followed by a ‘not charging’ issue which was a loose connection at the regulator. Replaced the plug, then later shorted one of the wires and killed the regulator. Threw a new battery in and rode the rest of the day without a hiccup!
Stay tuned- there’s a lot more to come on the ol bomb.
  • Excellent 2
  • Heart 1
Greentored
We love our horses best but respect these other bombers too. That yellow machine is an animal, powered by a fully built, 5000rpm K341, making close to 30hp!
  • Excellent 4
ebinmaine
I think it's awesome that you folks put time and energy into older machines and go out and play.
Good old heavy American iron that will last.
slim67
Is that mister studabaker? if so , its definitely bad ass.
19richie66
Looks like his machine.👍
