OldWorkHorse
1 minute ago, ebinmaine said:
I've got extra rims I'd give ya. Just come get 'em.
Tires are online all over the place.
I may even have chains but I'd have to look.
Wow that be great. I'm not sure how to fully use this website atm so idk how to PM but I'm in Lewiston Auburn area not sure how much of a haul you are from there
OldWorkHorse
4 minutes ago, pullstart said:
Nice light bar!  Having forward and rear mounted lights will surely help you, just make sure they are pointed as so to not get in the back of the snow shot... the reflection off the snow might hinder your actual sight.
Yeah the ones going on this bar are amber and couple small reverse LEDs
ebinmaine
PM sent as example.
Distance maybe 75 to 90 minutes. ??
I'm down by Cornish.
45 minutes or so from exit 63 in Gray.
OldWorkHorse
5 minutes ago, ebinmaine said:
PM sent as example.
I work in the bridgton area so I'm all over the lower half.
peter lena
OLDWORKHORSE, like your headlight set up, can you give us some detail info on them?  brand, price, where you got them ?  thanks , pete
WVHillbilly520H
13 hours ago, OldWorkHorse said:
I've never been much of a cab guy myself but I'm also not much for a frozen beard. So it's a love hate relationship. The helmet is a good idea alot easier to put away at the end of the year too
I thought the same thing but it makes a world of difference.
  • Excellent 3
OldWorkHorse
I'm cheap when it comes to headlights. I just went on ama-zon pick up a decent set of 4 inch round leds with a switch and relay with a fuse set up and wired them straight to the battery. Brite as all be and fit perfect. I got sum threaded rod with a nut to put back in old bolt holes and then got a piece of bar steel and cut to length used sum washers and wing nuts and just used it to hold them in nice and snug.
Edited by OldWorkHorse
Fat thumbs small keyboard
OldWorkHorse
They are a very easy and only owning my wheelhorse a short time I must say a massive improvement over stock. Not flickering in the lights or anything. And no modification to the hood so OG bulbs can b put back in if wanted to. I tucked old wiring away and just bypassed it with new stuff but all still there for original. (Hood to 314 b4 the restore)
OldWorkHorse
That things a beast. Cant wait to finally bury mine in sum snow. (I know carful what you wish for) is that a 2 stage or single?
WVHillbilly520H
That's the 2 stage but I used a tall single for many seasons before finding it... Basically the same scene except really wet heavy snow or DOT plow banks that's the only times I actually see the 2 stage is better (again just my experiences).
OldWorkHorse
She ain't pretty but shes solid. :icecream:
  • Excellent 2
ebinmaine
Looks good from here
OldWorkHorse
All painted and mounted up. Hopfuly works like I see it in my head :eusa-think:. Just need the lights now.
peter lena
old work horse, returning from my sons in VT , we followed a dump truck that had the entire rear square of the dump bed as a break light/ flasher set up , just a little bigger than yours , could not miss it , pete
OldWorkHorse
Lol. :eusa-think: I feel I might need to hunt that truck down. I bet it would bolt right up to the horse. Worse come worse plow dont see me It would probly stop it ha.
OldWorkHorse
So far its working. Lights kinda mounted need be adjusted. Wires are all run. Just need to make a mini switch box to mount the plug in and switches and the mount it to the bar. :happy-smileyinthebox:
OldWorkHorse
This should work. Turn lights around in the summer mow all night, I dont think the neighbors would mind ha. :techie-idea:B)
  • Excellent 2
ebinmaine
Bring that down to the meet and greet and you can be the night guide for a woods ride.
VERY nice!!!
  • Haha 1
OldWorkHorse
VERY nice!!!
That is very tempting haha. I need sum weights on the back of her that blower is dam heavy. Bar came out pretty good for scrap steel and pipe dreams. Just need make a switch box and I'll be on to next project.
ebinmaine
Fluid fill the tires and keep an eye on the cl..
OldWorkHorse
Cl? Lol.
ebinmaine
Craigslist. Oh and Uncle Henry's!
OldWorkHorse
Lol yes. Sorry my short hand can be rusty sometimes.
ebinmaine
No worries.
I regularly have to "search" for meanings of those type abbreviations.
  • Haha 1
OldWorkHorse
Putting together switch box for light bar.
  • Similar Content
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • sraces
      By sraces
      I purchased my 314-8 new in February of 1996.  It's been a great tractor.  But a few years ago I had landscaping done and contracted for lawn service.  So the tractor has been sitting in the garage for a few years.  Bought a new battery.  It cranks hard, but won't fire.  Probably needs the fuel lines or carburetor cleaned.  It also needs the clutch shock replaced.  I have the new shock and belt.  Just haven't gotten around to replacing them.  Deck is in excellent shape with new spindles before I parked it.  Comes with the nice pull behind spreader that has only been used twice.
      Thanks for you consideration.
    • sjoemie himself
      By sjoemie himself
      You know those people that have too many projects?? Yeah me neither!
      Another tractor added to the heard. Case International 585 with canopy/sunroof.
      It's a 60-ish horsepower tractor with very limited electronic gimmicks. Has a nice tight turning radius. It was built in Doncaster from 1985 to 1990 and the hourmeter says it has ran 4700 hours since then, I'll take that with a grain of salt though.
      Plan is to use it for all kinds of jobs around the house and barn/stable for my gf's horses.
      Ofcourse it is not a new machine so there are things that will need looking after but all the basics are there.
      Pictures you say? Sure!
    • PWL216
      By PWL216
      I have for sale a 1984 C-105 with deck and Snowblower. I got this as part of a package. There’s no battery and I haven’t tried to start it. I’m selling it as a project. The deck has one spindle out, but with it, as prior owner claims bearing was replaced. The snowblower has the flag and looks to be in very good condition. All but 1 tire holds air. The mower is complete. Includes mule drive. The extra hood (c-175) you see in the picture can go with the tractor for an additional $50. Thx for looking.
    • Spottedeventer
      By Spottedeventer
      Hi! The shafts of my fathers old 314-8, deck number 73449 have worn to the point the blades don’t stay secured. I’ve struck out tonight trying to find a part number. If anyone can assist, I would greatly appreciate it.
      thank you,
      Patricia
