danweikert21
Plowing rig
danweikert21
Oh well I would only be filling them for about 3 or 4 days
danweikert21
Just for when I’m pulling
WVHillbilly520H
5 minutes ago, danweikert21 said:
Magnesium chloride
Most likely its Calcium Chloride and if you don't use tubes just like said above will corrode your wheels...
 That stuff is nasty ain't good for the environment you may want to rethink this.
danweikert21
Ok I’ll try to fill with water
ebinmaine
4 minutes ago, SylvanLakeWH said:
That will eat your rims...
:twocents-02cents:
I was thinking the same thing.
MAKE SURE YOU INSTALL TUBES. That is NOT NEGOTIABLE unless you want new rims very very soon.
danweikert21
Just texted my buddy and we’re going to use water so I think that should be fine
ebinmaine
Ask if you can get rim guard or some other sugar base instead of a salt base
ebinmaine
Water is kind of okay but there are issues with that as well.
When you go to remove it you must remove the tire from the rim and wipe out the interior to be sure that it's completely dry or you will still be forming some sort of rust scale and damaging the metal.
danweikert21
Ok sounds good thanks guys I’ll make sure to dry them afterwards
slim67
I am guessing that this is a one time thing and after you hopefully win , you will empty the tires of the water? If not then take everyone advice and add the calcium to keep it from freezing along with inner tubes. Have fun.
danweikert21
Yeah it’s just a one time thing so I’ll take the tires off and dry the rims and stuff. But yeah I hope I do don’t want to get shamed in front of everyone haha thanks guys
slim67
Just check out those mega trucks on the tug pad. They really weigh them down. Also they tug on concrete to avoid digging a hole.
