johnnymag3
C 160 wiring ALL
sparkie333
10 hours ago, johnnymag3 said:
Picture ??? sparkie333.....:)
My post number 35 for pictures of C160 of sparkie's  tractor
Clarence T. Nolley Jr
Hello
Sparkie333, my name is Clarence and i have a C160 that i just reassembled and aim looking for good rewiring diagram for it, if you can send me some pic's and tell me what it cost i would greatly appreciate that thank.
gwest_ca
3 hours ago, Clarence T. Nolley Jr said:
Hello
What is the model number off the ID plate for your tractor?
We may have the correct diagrams.
Garry
Hello
Garry i will send that to you, i have closed my shop for today but i will find it and send that info, thanks again Clarence.
Hello
Garry again Clarence i looked at my manual and found it in the back cover of the manual.i will still send you that info.
sparkie333
Sorry I been away from my computer---I just got many things going on.  I think I have a extra wiring set for the C160--- I would have to look but there is one used that is in my shop.  I bought it for a spare and have not needed it. I don't think there is a splice in it. --- I will see about the diagram---I got one just having some problems as of late.
sparkie333
HI;  Clarence  I'm trying to send you a diagram---and a picture of my C160 Automatic. Just having problem with my computer.
I hope this will help I don't know why it keeps cutting the top of page  but it is just about all there. Ok it just cut it off on what I was seeing it is all there.  Good luck.
Edited by sparkie333
new info.
gwest_ca
What manual did you get this from? Never seen anything like it from Wheel Horse.
Hello
Garry thanks so much for the wiring images, i got both of them fine and i hope your computer problem will be resolved soon. Thanks again a have a blessed Day.
sparkie333
I just came to my computer because it just come to me 15min. ago that I sent the diagram that goes to the 200 series John Deere Garden Tractors. The pictures I was trying to send was of my WH C160 so I thought that was what I had for the diagram. I just had a brain fart. Sorry Guys
sparkie333
1 hour ago, Clarence T. Nolley Jr said:
Hello
Clarence  I'm glad you got what you needed for your C 160.  So I messed up on what I had so no diagram and and the wiring harness was for my John Deere's ---my bad.
I knew someone on here would help. --Well give me a B for trying.  There is not a whole bunch to the WH harness. Good Luck.
Man you have some idea diagrams--I like the color code view of the wires. You knew what I did and thanks for letting me off ease.-- I did put up a reply that I was thanking of my C160 But sent a 200 series diagram.
sparkie333
I will try to put up a picture or two.  Note: I may have to reload some of them seems like I wiped out some but should have them on save stick. These are not my best pictures of this tractor. Like I said I lost them till I can get my computer guru over here he has some other things to fix on my comp. Thanks.
gwest_ca
If that is a John Deere diagram the only difference is some of the wire colors. All components including the ignition switch are identical.
Garry
sparkie333
Garry
Yes I thought the same thing. One other thing I see is the number of head lights.
Hello
Garry great looking C160 i hope i can get mine looking that good.and thanks so much for the Diagrams.
