The Tuul Crib
Correct valve and piston for a charger
The Tuul Crib
I want to add the lift valve and the piston for the deck and the blade. But I want to make sure I get the correct one for this. I have a couple of sources for parts here but before I make the decision I want to make sure it is correct.was  it an option
or did they not put it on the charger?
pfrederi
Hydro lifts were standard on Electro's and optional on chargers.  Same unit. 8-4111
The Tuul Crib
Is this the part number of the valve?
pfrederi
The whole package.  if you want part numbers of the various components look at a manual for Electro's
  • Excellent 2
ebinmaine
@pfrederi
Paul what's the purpose of #14?
Something to be adjusted?
gwest_ca
#13 is a bracket to hold decal/scale #40.
#14 is a pointer to show the position of the lift on the decal.
Garry
ebinmaine
Garry
So is #14 used on a 1970 model year Charger considering it has an indicator on the top of the console?
gwest_ca
item 14 is part number 6649.
Shows up on many 1966-1977 models but not on the Charger until 1972.
I don't know what you have.
Garry
pfrederi
Eric:  All 5 of my Charger Electros have this set up. Decal is visible just above#14 indicator   Where is your indicator???
ebinmaine
I'm not at home so I can't take pictures of it. The valve assembly and the bracket for the indicator was all removed and switched over to what I assume is a generic log splitter type valve.
The indicator on this particular tractor is just a hand-drawn little note on the top cover plate.
