OldWorkHorse
1st wheelhorse and 1st restore
wfrpalm
That sure cleaned up nice.
peter lena
oldworkhorse, nice recovery on that , did you use an oil lubricant or paint cleaner to bring that paint out ? looks like its been cared for now ,  good job, pete
OldWorkHorse
I actually did a full re paint. Took about 4 months. Top to bottom. Not my best work. But I do like the outcome and very proud of this rig. Have the 48" deck and bagger as can be seen in OG photo but due to cold new England weather the snowblower resto came 1st.
OldWorkHorse
OldWorkHorse
6 minutes ago, OldWorkHorse said:
I found this site hunting for parts for the 314 and I found someone who makes all new decals so I stripped down and did full paint and stickered it back up to the best of my knowledge witch at this point is limited but slowly learning about them. This site has been most of my info.
  • Like 4
Pullstart
Awesome work, it looks tough!
OldWorkHorse
Thank you! Shes a beast! Only time I've been looking forward to snow. Haha
SylvanLakeWH
Nice job!
:handgestures-thumbupright:
rjg854
Looks like a new tractor :text-bravo:
WHNJ701
The ag's give it a good stance
OldWorkHorse
Yes they do 23x10.5-12 on the rear were enjoyable to put on the rear to say the least lol. Some tough rubber.
  • Similar Content
    • sraces
      By sraces
      I purchased my 314-8 new in February of 1996.  It's been a great tractor.  But a few years ago I had landscaping done and contracted for lawn service.  So the tractor has been sitting in the garage for a few years.  Bought a new battery.  It cranks hard, but won't fire.  Probably needs the fuel lines or carburetor cleaned.  It also needs the clutch shock replaced.  I have the new shock and belt.  Just haven't gotten around to replacing them.  Deck is in excellent shape with new spindles before I parked it.  Comes with the nice pull behind spreader that has only been used twice.
      Thanks for you consideration.
    • Spottedeventer
      By Spottedeventer
      Hi! The shafts of my fathers old 314-8, deck number 73449 have worn to the point the blades don’t stay secured. I’ve struck out tonight trying to find a part number. If anyone can assist, I would greatly appreciate it.
      thank you,
      Patricia
    • colbyeast
      By colbyeast
      Looking for someone in the Northeast (New England area) that can look at my Kohler Magnum 14 ( over 2000hrs
      )had rebuilt about 2 years ago (very little hours after rebuild)it's now blowing white smoke and going through oil, (checked breather :ok; cylinder has carbon build up no wear on cylinder wall) Could it be rings gone?Also needs carb work (throttle linkage very loose) Thanks in advance
    • ryobi.warrior
      By ryobi.warrior
      The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
      I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
      Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
      Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
    • ashtonosborne2019
      By ashtonosborne2019
      I just got a 1993 toro wheel horse 314-8 today for free. It seems to be in good working order hasn't ran since last summer. Came with a mower deck, rear wheel weights, and a snow plow. My plan is to take the transaxle out if i don't like the motor and put the trans in my 520-h hopefully it works. Is there any pointers you guys could give me i would really appreciate it... thanks.
