A-Z Tractor 244 #1 Posted October 16, 2020 A-Z Tractor is now offering an axle hub for the 1" and 1 1/8" axles. This is called a repair hub. This hub is manufactured with a tapered hub that clamps down on the axle when installed. This will help with axles that have a worn keyway and axles that might be wore from bad hubs. Also this hub is very easy to remove for future repairs. To purchase these hubs you can either call A-Z Tractor at 1-717-821-2542 or you can go on the website at a-ztractor.com and purchase them on the sight. To find the repair hub on the sight just type in the part number of the hub you are replacing or type in repair hub. When these hubs are installed properly under most conditions the hub will not turn on the shaft even if there is no key installed. These hubs sell for $110 each and when you are purchasing you have to select the correct one for your shaft size. The same mounting hub is used just a different center shaft hub for the different size shafts. 5 9 2 Share this post Link to post Share on other sites
Achto 30,172 #3 Posted October 16, 2020 Genius !!!! 2 Share this post Link to post Share on other sites
Stepney 2,356 #4 Posted October 16, 2020 Thats brilliant! We do the same with our old hit and miss engines. No idea why this idea never crossed my mind. 2 Share this post Link to post Share on other sites
squonk 44,859 #5 Posted October 16, 2020 (edited) We use tapered hubs all the time for industrial electric motors like on pumps and fan drives. You figure out where the hub/pulley needs to be, slide the center piece into it and then tighten the screws. The center piece is split. The hub/pulley has a taper and as you draw it in with the screws it clamps down on the center piece clamping it to the shaft. https://dpk3n3gg92jwt.cloudfront.net/domains/bbman2/bushinginstallation.pdf Edited October 16, 2020 by squonk 1 1 Share this post Link to post Share on other sites
ebinmaine 75,704 #6 Posted October 16, 2020 EXCELLENT Share this post Link to post Share on other sites
Skipper 1,790 #7 Posted October 17, 2020 @A-Z Tractor Any chance these will be available in the wider and deeper C195 and D series 6 hole hub style (and a few more i think) ? 1 Share this post Link to post Share on other sites
A-Z Tractor 244 #8 Posted October 20, 2020 Yes I plan to have this style available in the 6 lug for the C195 and D series. I also plan to have them for the GT14 and 953, 1054 the 4 bolt. 1 Share this post Link to post Share on other sites
