metalhead0920 10 #1 Posted October 16, 2020 Hello people, new to this site. I recently purchased a wheel horse 1077. And I can not find any info about the transmission. I just want to know what to use for fluid and what type of filter it takes or at least a number to cross reference. Any info would be greatly appreciated. 1 Share this post Link to post Share on other sites
pfrederi 17,866 #2 Posted October 16, 2020 Welcome; Check the existing fluid it should be red in color. If it is use Dex/Merc transmission fluid. Filter is Wix51410 3 Share this post Link to post Share on other sites
bottjernat1 2,190 #3 Posted October 16, 2020 Yep alot of the old horses used the same filter. The wix one is the way to go. They are the best in my opinion. 1 Share this post Link to post Share on other sites
metalhead0920 10 #4 Posted October 16, 2020 I agree. As a former Carquest employee Wix has as special place in my heart..Lol. Awesome, thank you for the info. Will post pics once I get it reassembled. 2 1 Share this post Link to post Share on other sites
metalhead0920 10 #5 Posted October 16, 2020 Oh, one other thing, do I fill it all the way to the top of the filler tube? Share this post Link to post Share on other sites
bottjernat1 2,190 #6 Posted October 16, 2020 1 minute ago, metalhead0920 said: Oh, one other thing, do I fill it all the way to the top of the filler tube? Well my d160 has a dipstick. and so does my daughters 1969 electro 12. not sure on yours i would say not to the top! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,096 #7 Posted October 16, 2020 Welcome to the forum. Here is a folder on the 1077. Click on the picture for more info. You can click on a picture taken from the Lubrication Chart Here is everything that comes up with a search for 1077. https://www.wheelhorseforum.com/search/?q=1077&quick=1&type=downloads_file Garry 1 Share this post Link to post Share on other sites
pfrederi 17,866 #8 Posted October 16, 2020 (edited) There should be a dipstick as part of the cap. It may have been lost and someone substituted a plain pipe plug. Fill it to about an inch below the top of the transmission housing Edited October 16, 2020 by pfrederi 2 Share this post Link to post Share on other sites
metalhead0920 10 #9 Posted October 16, 2020 Yeah no dipstick on mine. Just a tube under the seat. Share this post Link to post Share on other sites
metalhead0920 10 #10 Posted October 16, 2020 Yeah that's exactly what I have. Ok, thank you. Share this post Link to post Share on other sites
Ed Kennell 38,644 #11 Posted October 16, 2020 11 minutes ago, pfrederi said: Welcome; Check the existing fluid it should be red in color. If it is use Dex/Merc transmission fluid. Filter is Wix51410 Just be aware it is possible a PO converted it to motor oil. Do not mix oil and ATF. 1 Share this post Link to post Share on other sites
metalhead0920 10 #12 Posted October 16, 2020 Ok good to know. Those manuals are super helpful, thank you. What is a po? And why would they convert to motor oil? Is there a benefit and can you convert back? Share this post Link to post Share on other sites
Ed Kennell 38,644 #13 Posted October 16, 2020 PO is previous owner. I believe earlier WH autos used ATF and later used motor oil. I am not sure on the models and dates. Both fluids work . They can be converted, but should be flushed to remove all the fluid. Best to stay with what you find in yours. Red is ATF. Amber is motor oil. 4 Share this post Link to post Share on other sites
ebinmaine 68,344 #14 Posted October 16, 2020 Welcome aboard. We like to see pictures of all stages of projects and conditions of tractors so feel free to post whenever. Share this post Link to post Share on other sites
metalhead0920 10 #15 Posted October 16, 2020 Ok, got it. Well at least now I know where to start. Greatly appreciated guys! 2 Share this post Link to post Share on other sites
bottjernat1 2,190 #16 Posted October 16, 2020 14 minutes ago, Ed Kennell said: PO is previous owner. I believe earlier WH autos used ATF and later used motor oil. I am not sure on the models and dates. Both fluids work . They can be converted, but should be flushed to remove all the fluid. Best to stay with what you find in yours. Red is ATF. Amber is motor oil. Yes my daughters 69 electro12 is atf my 76 d160 is 10w30 Share this post Link to post Share on other sites
WHX?? 49,158 #17 Posted October 16, 2020 (edited) Good advice Ed, I have two 1077's and one 1277 and some use ATF but my go to 1077 I run 10/30 synthetic in. I think ATF is a better choice as when you engage the clutch idler it loads the motor up. Especially when cold. ATF is not quite as bad. Metal! Edited October 16, 2020 by WHX24 1 Share this post Link to post Share on other sites
Ed Kennell 38,644 #18 Posted October 16, 2020 26 minutes ago, metalhead0920 said: And why would they convert to motor oil? Is there a benefit and can you convert back? Like most decisions to change working designs and products. They are probably driven by cost reduction. Jim makes a good point above. Motor oil requires more warm up time during cold weather use. Warm up is probably a good practice for the engine and hydro regardless of the fluid used. All my hydros have 10W30 motor oil. 1971 Eaton 6, 1974 Sundstrand, 1980, 1986, 1988 Eaton 1100s Wheel Horse warns to prevent damage the Eaton 1100 must be warmed for 10 minutes before use. The lift on one of my Eaton 1100s will not operate until after the 10 minute warm up. The other two lift immediately. 3 Share this post Link to post Share on other sites
Ed Kennell 38,644 #19 Posted October 16, 2020 Oh, pardon my manners Metal. to the 1 Share this post Link to post Share on other sites
metalhead0920 10 #20 Posted October 16, 2020 Haha, thank you, will do! 1 Share this post Link to post Share on other sites
ebinmaine 68,344 #21 Posted October 16, 2020 Just now, metalhead0920 said: Haha, thank you, will do! You'd almost get the impression that us 5-year-olds like to look at pictures 1 Share this post Link to post Share on other sites
ebinmaine 68,344 #22 Posted October 16, 2020 14 minutes ago, Ed Kennell said: cost I don't mean to make anybody in here sound 3 weeks older than dirt or anything but was ATF expensive compared to oil back in the early 70s? Share this post Link to post Share on other sites
Ed Kennell 38,644 #23 Posted October 16, 2020 For some reason, I don't remember the 70s Eric. But I do remember paying $0.19 for a gallon of Good Gulf Gas in 1958. Guess that makes me a couple years older than dirt. And ATF did cost more than motor oil. 3 Share this post Link to post Share on other sites
pfrederi 17,866 #24 Posted October 16, 2020 Maybe the change was because Captain Ahab retired from whaling. Original Type A ATF and early Dexron used Sperm Whale oil as an ingredient... 3 1 Share this post Link to post Share on other sites
WHX?? 49,158 #25 Posted October 16, 2020 That I did not know Paul. Same here on the Eatons Ed. Especially when moving snow. 1 Share this post Link to post Share on other sites
