ebinmaine
A little foliage
Achto
Really nice colors Eric. My trees have been striped clean already. The wind has been blowing like crazy here for the last couple days and the forecast says that it's not going to let up for a while yet. .  Our leaves should be showing up on your door step in about 2 or 3 days.:D
  • Haha 2
ebinmaine
Generous of you. If a refrigerator box full of leaves shows up on your doorstep it wasn't me.
  • Haha 1
wallfish
Some years the peak foliage is so bright it looks like the whole place is on fire. Not sure what conditions affect it to make that happen or not so much.
Off topic-- Eric I see that inline fan is gone from the SSD system from when you had the oil spill. If you run a dehumidifier in the basement then you might want to consider having one connected again. A side benefit is it will remove moisture from under the slab floor and is much less expensive to operate than a dehumidifier is  I have installed system for that specific purpose only. If the VOC gases are gone and you don't have a radon issue, the vent stack above the roof line is not needed and you can locate the fan inside.
  • Thanks 1
ebinmaine
34 minutes ago, wallfish said:
inline fan
Good eye John.
Trina has it off so we can finish up the painting and trim on that corner.   It is going back up.
tom2p
nice !
  • Thanks 1
WHNJ701
The house came out nice!
  • Thanks 1
ebinmaine
She says thanks!
Almost done. One end has a fair amount of bees. She's waiting for the freeze to take care of them.
WHNJ701
32 minutes ago, ebinmaine said:
She says thanks!
I heard that from alot of people this year, my rental house had a nest too
ebinmaine
Yepp. Same up around here.
We have them in small nests several places up along the trim between that and the clapboards.
Digger 66
10 hours ago, ebinmaine said:
She says thanks!
What a KEEPER !
  • Heart 1
