71_Bronco
Unknown Sickle Bar Mower
71_Bronco
Going to pick up this unknown sickle bar attachment this afternoon. Came across it on FB Marketplace for a whopping $30.
I've been inspired by some of the other non-WH attachment builds, and thought I'd do one of my own if I came across the right parts.
Pics are from the ad, and I have not been able to really look at it yet and look for any tags or information.
It looks like it's all there and not much damage. All the blades / guards look to be there and intact.
Mods, if this belongs in a different section, please feel free to move it.
After doing a 10 second search on Google, it looks similar to a Simplicity model "B" Walk-Behind sickle mower. Not exactly the same, but along those lines.
953 nut
with a bit of ingenuity and persistence you can make it fit.                                 :wwp:
WHNJ701
I have a simplicity model b walk behind, if you want for free let me know
peter lena
71-BRONCO , that is an interesting set up, in addition to a thorough , LUBRICATION RESTORATION  , you could set that up on a bench and do some trial wake ups, having used 1/2" variable power drill to slowly check operation/ function on long dead mechanical items . I would also take up the offer  from  JABELMAN , on the walker to complete the set up . jmoo, pete
71_Bronco
I was thinking about attaching this to a plow frame, with a cross-bar between the 2 uprights. Then use solid strips to control the angle where the anti-tilt springs go.
I'd still have to figure out away to drive it though, and drive it at the proper speed.
If I were to adapt it to my Commando 8-8, this would be a pretty good match. I swapped in an 8-speed, so I will have the "low range" to drive the tractor slow if needed.
Pullstart
Cool tool!  The ground speed isn’t as important as the rpm’s I’ve found.  Whatever you do, try it slow or with a small drive pulley... or even an underdriven jackshaft setup :handgestures-thumbupright:
peter lena
71-BRONCO,  that 1/2" drill set up , would allow you to slowly verify operation , and lubricate it to life . i have done that with snow blowers , and various drives . it would also let you make adjustments , as you need them. that unit has been sleeping a long time , if it were me I would lubricate every movement point and try it by hand , if you can get it to cycle , then go to the drill , more lubrication and adjustments . after that i would go to an engine drive set up . jmoo, pete
71_Bronco
Just picked it up, heading home now. The pulley turns by hand and the blades slide back and forth like they are supposed to. Think I made out well for $30
Edit: Got home and put some fresh grease in all the fittings. Every pivot point / shaft has a fitting. Turns very smooth, no slop or play.
The blade assembly drags a little over the bottom bar, due to the surface rust. I'm probably going to pop it off, clean and grease it, then throw it back on and call it a day. Its in really nice shape considering its age and seems to function perfectly.
Edited by 71_Bronco
