snowhound
Traction in the snow
snowhound
In Sept. we had a new paved driveway put in the driveway has a fairly steep hill.  In the past I've used turf tires with chains on my snow blower tractor but am concerned about damaging the new pavement would bar tread tires give me decent traction?  I have cast iron weights and I go about 200 lbs.
ebinmaine
Ag tires won't be satisfactory to you especially in a hill.
What you need are RUBBER CHAINS.
And tons of weight. Enough weight? Add more.
@Ed KennellKennell is it you that runs rubber chains?
  • Like 4
doc724
Regular chains will scratch your driveway of you spin the tires.  I would stay away from bar tread chains.  Of course, if you are using a blower, there should be less spinning than if you are using a plow.  My driveway was not very steep, but I would put on cast iron weights and four 40 lb suitcase weights and chains and me had no problem with wheel spinning with a blower.
AMC RULES
Beet juice...filled tires all four corners.
ebinmaine
Yessir.
Like my Cinnamon Horse has.
pfrederi
I use rubber chains and a plastic edge on the plow for eh short length of drive with pavers.  Rubber chains work well  (not as good as steel) but they pound you as they are really 4 link. equivilent.
Racinbob
We have a long blacktop drive. I use 150# of wheel weights, a weight box hooked to a 2" receiver hitch and rubber chains on the tractor with the blade. The blower tractor has 110# of wheel weights and that's it. So far no issues with either but last winter wasn't a test. :)
Ed Kennell
Yep, I believe the rubber straps actually twist and act like a cut pulling tire when in loose snow.  And they have better traction than steel on a bare paved driveway.
 Steel is better on ice.   Weight=TractionIMG_6697.JPG.9c9dee8ec9e1638751b7e990ec552960.JPG
  • Excellent 2
WVHillbilly520H
Eric, I'm gonna have to disagree with you here , I have AG tires on my 520s fluid filled and iron weights plus a little more hanging out back of the snow chucker rig and DON'T use chains on our paved driveway without issues (of course your milage may vary)... my OTR Lawn Trac R1 has been an excellent traction tire on my 2 520s whether the blower or pushing a 56" snow plow or pulling a 10" Brinly or mowing my steep hills. Just my experiences here.
Edited by WVHillbilly520H
  • Excellent 3
ebinmaine
Mine were pretty slippery without chains. But maybe if I added more weight....?
WVHillbilly520H
IDK, I only have 5 gallons methanol in each tire maybe 75# iron each wheel. Then add the cab and another 120# on the blower tractor plus my 200... But the OTR (#2) have a different pattern than the Carlisle TruPower(#1) or Deestone equivalent(#3) that I had to run chains with, again just my experiences.
ebinmaine
Maybe those OTR are the difference?
Interesting straight spot in the center.
WVHillbilly520H
That center could be the tractive difference IDK... but no chains for 3 years they are definitely better than the Carlisle Trac Chief R4s on my Mahindra and even with fluid fill the sidewalls have plenty of flex.
ebinmaine
Forgive the slight side track of the thread here....
How's the mud traction?
WVHillbilly520H
So far here in my wet red clay soil gardening this summer no issues a few times I wondered if I was going to have to get a tow but they pulled on through or backed out and over I am truly impressed by this brand tire they can be had in 26x12-12 as well.
WheelhorseBob
The limiting factor here is the open differential rear ends these tractors utilize. On ice, no amount of weight or tire tread design will help. What you need is a device that digs into the ice. V-bar chain is the best. Different tires and rubber chains will work if you have dirt or pavement under the snow but as anyone in the snow belt who works for a living knows, by the time you get home after a snow/rain/ice storm the damage is done. I’ve spun the wheels on my F250 plowing our driveway because of ice. That’s with a locked diff and 4x4. Moral of this story, ice doesn’t care about tread design or weight!
  • Like 4
KrazeyOlDave
I’m wanting to fill mine with whatever is the cheapest but will not rust my rims, suggestions? Also, how wide are those rims? I could only find 10.5’s.
WVHillbilly520H
Rims are factory 520H and come in at 8.5" wide for a 10.50" wide tire there are some brand new ones on eBay but back spacing will be of a concern if Wheel Horse ... Mine are filled with methanol that farm shops use, but you could use RV antifreeze (the pink stuff) Or plain old blue windshield washer fluid.
WVHillbilly520H
On 10/4/2020 at 8:32 PM, WheelhorseBob said:
The limiting factor here is the open differential rear ends these tractors utilize. On ice, no amount of weight or tire tread design will help. What you need is a device that digs into the ice. V-bar chain is the best. Moral of this story, ice doesn’t care about tread design or weight!
I agree 100%,  but also with these GTs in my experiences a hydro trans has big advantage over a gear jammer in the snow/ice you are never in the wrong gear slow fast or just right.
ebinmaine
Check if you have a Rimguard dealer near you as well.
I can get tires filled with Rimguard for less than pink rv antifreeze most of the year.
Location. Location. Location.
Ed Kennell
Yes sir, about a 10X advantage if you are clearing smaller obstructed driveways where you changing directions constantly.
midpack
I got a set of rubber chains to keep from tearing up the paved driveway with steel. They work well except on ice.
I have about 115#'s on each rear wheel, 30#'s on each front and 200+ #'s in the seat  😆
