BMW1
Ross Steering parts for D series
BMW1
I was looking for Ross steering parts and "found" the gardentractorpullingtips.com/steering.htm website.
I have not ordered anything, only sent an email with questions.
Today I noticed the post in the Red Square Links for "not recommended suppliers".
I am glad I did not send any money.
I am rebuilding a Ross Steering box on a Wheel Horse D180.
The Ross Steering box has the code below stamped on the column.
SCA 10200
Where can I get these items?
-          Complete Lower Steering Box Bearing and Cup/Race Kit - Full Set. Includes two plastic bearing cages/ball spacers.
-          9/16" Diameter Cam Follower (Steering Pin).
-          Flanged Sealed Ball Bearing to replace the insert at the top of the column.  Looks like it's a little bigger than 1 3/8" OD with a 3/4" ID
-          “Easy Steer" Upgrade Kit. For models with 3/4" diameter pitman arm stud.
I have seen some of these parts on the auction site but was hoping for someplace I could order everything from.
Thank You.
WHX??
Maybe check on the Cub sites as well. Many cubs used the used the Ross box.
pfrederi
as did John Deere
pacer
As mentioned deere & cub & and others had this system, you just have to watch the cam follower being 9/16" and not 1/2". The kit below does not show the 'cage' for the bearings but you really dont need it. After you have got all that rotton old grease out and cleaned up (what a pain!!) put the shaft in a vise with the race facing up and liberally apply a good sticky grease all around it - its to act as a 'glue' and stack the balls all around the race and carefully set the housing over it. Usually the balls are alright and the cam follower has the wear....(and, you'll almost certainly not need the top set, I've rebuilt some 8-10 of em and the top bearing is always OK)
The bearing in the top of the tube is the same as the front wheel flanged bearing. I do have to wrap several rounds of masking tape around the bearing til it fits snug.
https://www.ebay.com/itm/Cub-Cadet-9-16-18-Cam-Follower-Stud-911-3149A-711-3149A-MADE-IN-U-S-A/222221431153
On the easy steer thing I prefer to go to McMaster and get a needle thrust bearing. .... or go ahead and get the kit off the bay as shown by@953 nut
Ah, those 'big D's' love the bit brute but they can be a pill to do repairs:o
oliver2-44
If you need to replace the steering tube on your Ross box due to it being heavily rusted you will find it is not a standard size tubing.  I replacing the tubing on my Case tractors Rpss steering box and learne don the Case site that the tubing from trampoline legs is very very close to the correct size.  I had to work the end that goes in the dox down a little with emery cloth and it worked great.
WheelhorseBob
Ross boxes are also on Economy Power kings. The Economy Power King collector's Facebook page has been helpful to me.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
    • Swemill
      By Swemill
      Hi everyone!
      Long time since i was here and my old pics is gone from the forum.
      I just uploaded a movie with pics on youtube, and thought i could share it for you guys.
      I would love to get some comments on my Youtube channel, from you true Wheel Horse fans!
      Thanks and Best Regards
