Countdown To Christmas!
The Tuul Crib
Throttle and governor connections
The Tuul Crib
Start to put my 16 horse  back together.
 Trying to remember which holes the spring goes in for the governor and throttle.
oliver2-44
MIne is 2nd from the top.
daveoman1966
These pics help...Its a 10hp but linkages are the same for a 16hp.
953 nut
This page is from the Kohler Repair manual found in our manuals section. It outlines steps to adjust governor sensitivity once you get it in the tractor.
peter lena
THE TULL CRIB , in addition to the prober routing , if you LUBRICATE  ANY FRICTIONAL MOVEMENT POINT , IT MIGHT WORK EASIER, detailed mine with added cable clamps to secure movement and improve action , also lube the starting point of the cable , to help out , pete
