W/H JUNKY 43 #1 Posted September 25, 2020 (edited) Hello all. I have another question. I have a c-141 the hydro trans. Works great but the cylinder for the lift will not extend. Now the trans fluid is full what is something else I can check to find out what is going on. Now it did lift the snowblower one time but after I let it down. It will not go back up. Thank you in advance. Edited September 25, 2020 by W/H JUNKY Share this post Link to post Share on other sites
rjg854 11,475 #2 Posted September 25, 2020 Is the transmission engaged? My C160 won't work the lift if I don't have the transmission engaged. 1 Share this post Link to post Share on other sites
W/H JUNKY 43 #3 Posted September 25, 2020 Yes it is. The pump is spinning. 1 Share this post Link to post Share on other sites
pfrederi 17,866 #4 Posted September 25, 2020 Tow valve in drive???? Share this post Link to post Share on other sites
953 nut 55,769 #5 Posted September 25, 2020 11 hours ago, W/H JUNKY said: it did lift the snowblower one time but after I let it down. It will not go back up Sounds like a linkage issue to me. Unless there is a catastrophic leak in the hydraulic system it should continue to work. Share this post Link to post Share on other sites
Pullstart 63,096 #6 Posted September 25, 2020 You could remove the hoses and route them to a bucket... to check for flow. When you move the lift control, do you hear anything different from the engine or transmission? Share this post Link to post Share on other sites
W/H JUNKY 43 #7 Posted September 25, 2020 Thats what I was thinking I was going to do. I can not hear anything different in the sound of the engine. Just weird. Share this post Link to post Share on other sites
Pullstart 63,096 #8 Posted September 25, 2020 If that doesn’t work, maybe try working backwards. Maybe the control is stuck? Take the pressure line off the control and start it for a second? Share this post Link to post Share on other sites
W/H JUNKY 43 #9 Posted September 25, 2020 This is crazy. Went out and started the tractor this morning and it lifted rite up. So I ran it up and down about 25 times then put the tire chains on it and ran it again about 25 times with no issues. May have had a air pocket in the line or something just glad it worked. Thank you guy for all of your suggestions and help. 2 Share this post Link to post Share on other sites
rjg854 11,475 #10 Posted September 25, 2020 So happy it worked out that easy for you. Share this post Link to post Share on other sites
