LumpyB 0 #1 Posted May 16, 2009 I have a 310-8 that I have been working on building a puller out of. When I got it there was no engine so it has been repowered with a k341. The rear rims were widened for the carsile 26x12x12 tru powers and the front are gbc tri ribs. The rear adjustable hitch and front weight bracket is done. All I have left to do is make the engine guards, wheelie bars and middle weight bracket then paint. I hope you guys like it and will give me some input. Share this post Link to post Share on other sites
Bill 4 #2 Posted May 16, 2009 Looks like you off to a good start Lumpy Keep the Air psi in the rears around 2 pounds, just enough to hold them on the rim but soft enough to give ya a good bite :omg: Share this post Link to post Share on other sites
poodle 0 #3 Posted May 31, 2009 that's one heck of a machine I wish I had a 16hp on my puller and I must say I'm also a bit envious of the tires and that's a massive filter you have on your carb how did you get that thing to stay on there? Share this post Link to post Share on other sites
LumpyB 0 #4 Posted May 31, 2009 Thanks you guys glad you like it. I welded a piece of exhaust pipe that was the same diameter as the inside of the airfilter to a plate. I used the original air filter plate as a pattern for the holes. I did have to notch the plate and pipr a little fot the choke the plated what I cut out back in. Share this post Link to post Share on other sites
josh416 2 #5 Posted March 8, 2010 i think the 300 and 400 series wheelhorse's are the strongest and cheapest $ wise puller's built ive had modifed cubs but they are 2 much 2 keep going :party: Share this post Link to post Share on other sites
rickv1957 73 #6 Posted March 8, 2010 Looks like a great start on your puller! Rick Share this post Link to post Share on other sites
KeithB 6 #7 Posted March 8, 2010 looking good, keep the pics coming B) Share this post Link to post Share on other sites
KeithB 6 #8 Posted March 8, 2010 i think the 300 series has a different 8 speed, the one with 1" axles i think? Share this post Link to post Share on other sites
