Pullstart
Oops, it Happened Again!
Pullstart
I do wish I could figure out why these towers get in such bad shape?  Battery acid possibly?  It”s under the steering wheel on the right.
  • Confused 1
  • Sad 1
Pullstart
All the others are turning their back to the Ugly Duckling.
  • Haha 7
formariz
I like it. Is it like an Army Green?
i am planning to paint a black hood like that.
Pullstart
Yeah... this might need some stencil paint and a white star...
Rp.wh
I kinda am liking i, I am also liking that garage with all them horses danggg!!:blink:
  • Thanks 2
Tractorhead
could there may be a widely fract of a possibility,
that they all are a little Snob‘s..
i like it.
Edited by Tractorhead
  • Haha 3
Shynon
That's where the manual PTO engagement bracket goes, had to repair mine also
Achto
Looks great Kevin.:handgestures-thumbupright:  Your shop looks to be getting smaller all the time though, might have to add on soon. :D
  • Haha 1
953 nut
:text-yeahthat:         I have a couple that have reinforcement plates added to the tower.
Edited by 953 nut
953 nut
9 hours ago, pullstart said:
My wife found it a while back and was trying to buy it for me for our anniversary
:text-coolphotos:             Could you wife teach my wife that trick?               :ychain:
  • Excellent 2
  • Haha 1
Pullstart
@19richie66 I believe you were Mrs. P’s advisor on this?  Can’t believe it made it here anyway!
This makes 1054 #2 and 2 953’s as well.  I have a feeling that tote of GT-14 parts is calling my name sooner than I think to get put together to round out the classic big wheel collection :handgestures-thumbupright:
Pullstart
71_Bronco
I thought I remembered a round hood (RJ maybe) on here that was painted in an army green theme, but I couldn't find anything on it.
I did find this one on Google Images. Maybe this can be an inspiration.
  • Excellent 2
Pullstart
You want me to paint it white?  :ychain:
71_Bronco
It's working here on my end...
71_Bronco
Here's the tractor:
Pullstart
 See it now, thanks!
19richie66
I saw it online and not far from the homestead so I shot her a message. She was already on it and I swore to secrecy. :handgestures-thumbupright:
prondzy
Pto engagement bolts there,  cracks and falls out. I welded mine
Pullstart
I’ll have to cut it out and weld in a good patch one of these days... or leave it for character!
Pullstart
Here I am, a bit torn.
The 953/1054 platform is my favorite for overall plow and young person operating machine.  Time might be the limiting factor on this idea before plow day.  Leroy is a 6 speed / limited slip 12 hp machine.  The tower is cracked at the lift arm and it doesn’t charge at the present moment.  Hot Wheels has a non-limited slip 6 speed in it.  Why not make Joe a brute with 12 hp tall tires, big ground clearance and limited slip?
19richie66
Just remember that the frame and transmission mounting holes are different on the 953/1054 platform. The regular wheel horse transmission will not bolt up. Now I believe the internals could be swapped into the factory case or you have to weld a new plate to the rear of the frame. Thats one of the reasons I swapped to a gt14 frame for Karen’s 2054.
Pullstart
Hey there @953 nut Richard, do you recall what you did for Hot Wheels by chance?
echris
@pullstart
You need to keep "The Ugly Ducking" just as she is. Sure, sort out the mechanical issues, but otherwise, she stays.
  • Haha 1
  • Similar Content
    • Pullstart
      By Pullstart
      5 big wheels, in various forms or stages.  One with melted wiring, one runner, one in need of an engine, one full project and one in the middle of nap time.  @953 nut thanks again for turning on my big wheel switch!
    • CasualObserver
      By CasualObserver
      1964 Wheel Horse sales brochure
      12 pages 651KB
      12 pages 2.1MB
    • wh315-8
      By wh315-8
      Have a 1964 WH 1054. The tractor will steer tight to the left but only half the angle to the right. Drag link will hit the stops on axle on both sides. The steering gear has more teeth to go on the right but stops on the axle stop. Linkage is all good and snug. Seems if I adjust the linkage I will put the wheels out of straight. Is this normal for this model? Haven't tried to adjust anything yet, still trying to study what I could change so that it will steer the same radius both directions. Will get up close pics to post later. The linkage from the main gear to drag link is connected from the bottom up. I notice some go from the top down, I studied mine and it seems to be correct because of the bend in the link to go under the frame. The stops may have been added later, but seems it could be factory; even w/o the stops it would steer in same way, just have more radius but still short to the right.
    • Bear G
      By Bear G
      Getting the 1st two of eight total ready to go to the show in New London, Oh. This weekend.
      the 857 and the 1054 still need some minor cleaning but they’re ready to load.
      Show is 7-27-18 to 7-29-18. Hope to see you there!!
    • M i k e
      By M i k e
      Boys, having problems with the front wheel alignment on my 1054a.  Seems as tho the tie rod is about 1/2" or so too short causing the front tires to pigeon toe.  Tore everything apart can find nothing wrong or bent.  According to WH parts diagrams, the 953 and 1054 tie rods are the same part number.  Perhaps one of you good fellas could give me the measurements of your tie rods so I can verify mines the correct length?  Maybe something else Im missing here?
      Thanks,
      Mike
