Tractorhead
Help with bearing on RMR3226 Deck
Tractorhead
Hi,
i need help in find replacements for the bearings and Oil- Seals on the RMR 3226 Deck
i like to rework few of them, because few bearings have little of play in it and the Seals doesn‘t work as needed.
Any help here from the experienced will be highly appreciated.
gwest_ca
Is this the deck you have? RMR-3226?
Garry
Tractorhead
Yes, that is the Deck i have sorry of the misstyped numbers.
Rmr 3262 was the right.
 i search for values, where i can get here at my side exchange parts
( bearings and oilseals) from SKF or ***
gwest_ca
Taken from notes so check to see if they are correct
1508 is a Torrington B-1212 needle bearing - 4 required
1515 replaced by 101480 and may be a SKF 1630-2RS ball bearing - 2 required
Bearing Needle Radial .750"x1.250"x.078" Torrington NTA-1220, Used on gear driven mower decks
99-3836 Replaces Wheel Horse 1534, 8571, 33589, 701021 Flat thrust bearing - 2 required
Bearing Needle Radial .750"x1.250"x.030" Flat race
Torrington TRA-1220, Used on gear driven mower decks Used with 99-3836, 1534, 8571, 33589, 701021 bearings
Wheel Horse 1535 Flat thrust race - 4 required
1303 seal - 2 required for deck and 1 required for idler pulley SKF 7410
Garry
Tractorhead
Thanks Garry,
that helps me a lot to build my resto-part Shopping list.. 👍
