Tractorhead 9,065 #401 Posted October 22, 2020 @Oldskool congrat‘s runn‘s great and looks pretty cool. what kind of paint you thinking about? plain Coat shall be the best solution for that project i think. 👍 Share this post Link to post Share on other sites
ebinmaine 69,075 #402 Posted October 22, 2020 On 10/22/2020 at 1:23 AM, Oldskool said: I'm looking for suggestions on bending some steel I suppose maybe you could start a new thread in the restoration and modification section 1 Share this post Link to post Share on other sites
Oldskool 6,658 #403 Posted October 22, 2020 On 10/22/2020 at 5:30 AM, JPWH said: @Oldskool what steel are you wanting to bend? I'm looking to bend 1/8" x 1-1/4 x 8ft angle iron. I'm looking to close the profile angle past 90 degrees. Basically to close the open side down to 3/4" and still keep the straight sides Share this post Link to post Share on other sites
wallfish 17,137 #404 Posted October 22, 2020 I tried that with shorter pieces than 8 ft but found it quicker and easier to just cut it and weld it. The corner is thicker so it wanted to curve the sides when bending it closed 1 Share this post Link to post Share on other sites
Oldskool 6,658 #405 Posted October 22, 2020 On 10/22/2020 at 10:41 AM, wallfish said: I tried that with shorter pieces than 8 ft but found it quicker and easier to just cut it and weld it. The corner is thicker so it wanted to curve the sides when bending it closed That's unfortunate. I need 12 and already would have to weld both sides as it is. I was hoping to not add another 96ft of welding on top of the 192ft I already have to do Share this post Link to post Share on other sites
ebinmaine 69,075 #406 Posted October 22, 2020 Could you use a different shape like a c channel? Share this post Link to post Share on other sites
Oldskool 6,658 #407 Posted October 22, 2020 On 10/22/2020 at 11:45 AM, ebinmaine said: Could you use a different shape like a c channel? I need a defined edge Share this post Link to post Share on other sites
ebinmaine 69,075 #408 Posted October 22, 2020 On 10/22/2020 at 11:48 AM, Oldskool said: I need a defined edge Yeah I figured that's where you were headed. Share this post Link to post Share on other sites
Oldskool 6,658 #409 Posted October 22, 2020 On 10/22/2020 at 11:49 AM, ebinmaine said: Yeah I figured that's where you were headed. I will figure out something Share this post Link to post Share on other sites
Pullstart 63,259 #410 Posted October 22, 2020 Huh. I can’t imagine what that shape would be used for... 1 1 Share this post Link to post Share on other sites
Oldskool 6,658 #411 Posted October 22, 2020 On 10/22/2020 at 12:44 PM, pullstart said: Huh. I can’t imagine what that shape would be used for... Nothing if I cant make it lmao 2 Share this post Link to post Share on other sites
JPWH 6,149 #412 Posted October 22, 2020 If I understand correctly you want 1/8th steel bent to more than a 90. is this correct? If yes check with a sheet metal shop. My machine shop friend said he can do it in his shop. Share this post Link to post Share on other sites
Oldskool 6,658 #413 Posted October 22, 2020 On 10/22/2020 at 5:42 PM, JPWH said: If I understand correctly you want 1/8th steel bent to more than a 90. is this correct? If yes check with a sheet metal shop. My machine shop friend said he can do it in his shop. Yes you are correct. All the shops near me have older equipment and cant go passed 90. Share this post Link to post Share on other sites
bds1984 1,457 #414 Posted October 22, 2020 Could you get some 1/8" flat at 2" wide and have it folded back? I have an ancient Tennsmith brake that could do that. If you need a certain radius at the bend, one can run a wire or small diameter round stock in it to maintain shape. Share this post Link to post Share on other sites
Oldskool 6,658 #415 Posted October 22, 2020 On 10/22/2020 at 6:31 PM, bds1984 said: Could you get some 1/8" flat at 2" wide and have it folded back? I have an ancient Tennsmith brake that could do that. If you need a certain radius at the bend, one can run a wire or small diameter round stock in it to maintain shape. I'm going to check with a machinist buddy of mine in a few minutes and see what he says. He may have a way Share this post Link to post Share on other sites
Oldskool 6,658 #416 Posted October 22, 2020 Well everyone I may be able to start the next build sooner then I thought. Cause ive got the fever. You may not wanna miss this one. 1 1 1 Share this post Link to post Share on other sites
ebinmaine 69,075 #417 Posted October 22, 2020 On 10/22/2020 at 9:00 PM, Oldskool said: Well everyone I may be able to start the next build sooner then I thought. Cause ive got the fever. You may not wanna miss this one. I wouldn't miss any of them. The question is, how in the world are you going to get the honey do list done and also keep all of us five year olds happy? I think you can do it. Might take some extra caffeine but I think you can do it.... 1 1 Share this post Link to post Share on other sites
Oldskool 6,658 #418 Posted October 22, 2020 On 10/22/2020 at 9:12 PM, ebinmaine said: I wouldn't miss any of them. The question is, how in the world are you going to get the honey do list done and also keep all of us five year olds happy? I think you can do it. Might take some extra caffeine but I think you can do it.... Oh I've been knocking stuff off my list. I really want to get this need build started. It may take a while getting this one done. No caffeine here. Never touch the stuff. It makes me all antsy. I would get alot of nothing done 1 Share this post Link to post Share on other sites
Oldskool 6,658 #419 Posted October 24, 2020 Might have an addition to the herd. Waiting for a response from the owner. No deck. Good for parts Share this post Link to post Share on other sites
Oldskool 6,658 #420 Posted October 24, 2020 On 10/24/2020 at 10:05 PM, Oldskool said: Might have an addition to the herd. Waiting for a response from the owner. No deck. Good for parts Is this actually a 61? Looks newer to me Share this post Link to post Share on other sites
wallfish 17,137 #421 Posted October 24, 2020 (edited) Not even close to a 61 and certainly not a Toro 1974-77 Edited October 25, 2020 by wallfish Share this post Link to post Share on other sites
Oldskool 6,658 #422 Posted October 25, 2020 On 10/24/2020 at 11:57 PM, wallfish said: Not even close to a 61 and certainly not a Toro 1974-77 I thought it looked like a mid 70's. So it would be this style grille? Share this post Link to post Share on other sites
wallfish 17,137 #423 Posted October 25, 2020 And a 8 hp Kohler has got to be the easiest engine to get running. Seems like they all WANT to run. 1 1 Share this post Link to post Share on other sites
Oldskool 6,658 #424 Posted October 25, 2020 On 10/25/2020 at 12:14 AM, wallfish said: And a 8 hp Kohler has got to be the easiest engine to get running. Seems like they all WANT to run. Cool. I was thinking of getting it for parts but we will see. It might end up as a later project. 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #425 Posted October 25, 2020 On 10/25/2020 at 12:22 AM, Oldskool said: Cool. I was thinking of getting it for parts but we will see. It might end up as a later project. Twin engine? Share this post Link to post Share on other sites
