Oldskool
Johnny Ca$h Round hood
Tractorhead
Self hiding gas cap‘s must be captured with a chain..
Oldskool
Go on. Tell me more. I need to get the little bugger
  • Haha 1
ebinmaine
I've consulted the local expert panel which basically consists of Trina.
Her suggestions are as follows:
The top of a toolbox.
A shelf just above eye level.
Think of the one or two places that you would NEVER put it and check there.
My own thoughts are that it is in a box, bin, or container that is light colored such as silver or white.
Due to the fact that Murphy of the well-known Murphy's Law is often known to show up around my area I would suggest that you check something opposite to what I just said such as a BLACK BAG.
The practical part of me is thinking that it would be obvious the last place you had it is in, near, or because of, the process of coating the inside of it so look wherever those chemical containers ended up.
Oldskool
Trina had some good ideas. You as well, but it wasn't in any of those places. As far as Murphy goes I threw him out of the garage long time ago. Never to come back. Very troublesome. It just so happened when sealing the tank I had the cap in my shirt pocket. I apparently went somewhere afterwards and placed the cap in the pocket of the door in my truck.
  • Excellent 3
  • Haha 1
ebinmaine
Because where else would I possibly put a fuel cap............
  • Haha 2
Oldskool
Exactly. Although I did immediately go to the garage and put it on the tank. The test drive IS ON
  • Excellent 2
Stormin
I assume it is now in progress and the report will be posted before I go to bed in 3hrs time.?
Oldskool
Should be a video on about 1.5hrs or less. I'm scrounging around for parts at the moment
ebinmaine
That gives you a 1.5 hour buffer time
Stormin
I'll have to catch it in the morning. 10-35pm here and I'm bushed.
  • Sad 1
Oldskool
  • Excellent 5
Oldskool
  • Excellent 5
  • Heart 1
rjg854
Awesome work on that tractor. Looks fantastic, I even like that chrome like look. You dun reel good.  :bow-blue:
  • Thanks 2
Oldskool
Thank you. Gonna get paint sometime this winter
SylvanLakeWH
:notworthy:
Oldskool
Is there a fabrication section here somewhere?
ebinmaine
If there isn't maybe there should be....
Oldskool
I'm looking for suggestions on bending some steel
Pullstart
On 10/17/2020 at 7:49 PM, Achto said:
Check the fly wheel key. I have found that if I have every thing that I need on a Briggs but it won't run, chances are that the fly wheel key sheared some how.
Could that be what’s up with that diesel genny I can’t get to fire?  It would knock timing off and lose compression, wouldn’t it?  That has a ton.
Pullstart
On 10/19/2020 at 11:38 AM, Lee1977 said:
Steel wheels.
 I saw some lawn rollers made by Brinly (?) last Sunday that bolt on like wheel weights and cover a tire... they were about 24” wide.  They were so cool!
Achto
Only if the injector is fired electrically from a magnet on the fly wheel. I would guess that your diesel engine is all mechanical though. It still could be out of time some place though.
Pullstart
Even juice down the throat didn’t fire it.
Oldskool
Mechanical injector? If so it still may have sheared the key on the drive gear or maybe even half way sheared
JPWH
@Oldskool what steel are you wanting to bend?
Stormin
Thanks for the vid's. :thumbs: Sounds and looks grand as owt.
