bc.gold
Lodge & Shipley Single Wheel Tractor
bc.gold
Bought this mower from a neighbour, $40.00, the old Briggs turns over almost making a complete 360 probably a stuck valve.
Manufactured by Lodge & Shipley better known for metal working equipment.
Edited by bcgold
bc.gold
Appears the sickle bar was an attachment for the single wheel Choremaster tractor.
Edited by bcgold
Stepney
I had a Lodge like that, still have a Lodge gas engine too.
Looks like an old Model N Briggs?
If it turns and the rod is there.. it'll run, as I have found. My Lodge looked a lot like a Choremaster.. actually the older Choremasters looked like your machine too. Think there was a connection there.
bc.gold
Today, many of the original Choremasters have been converted into home made 'vehicles' for carrying folks here and there at tractor shows.
Something called a Roto Spader at  the neighbours farm which has a small Lausen horizontal shaft engine on it, I have absolutely no interest in owning it.
Stepney
I had a RotoHoe myself.. same sort of idea.
Looked like some nightmarish front tine tiller.. but did nothing for tilling. Rather, it had a rear mounted hoe, and the bizzare front tines were simply for clawing its way through the dirt.
Interesting rig.. pile of junk to use though. Same with the Spader.
I worked on a dozen choremasters.. make good butt buggies haha.
bc.gold
Yes it is a Briggs Model N, this engine was used when a customer ordered accessories requiring the extra horse power, like the reel mower, sickle bar and the snow plow.
The Clinton engines were the most common, in fact Clinton even made a chainsaw to run off the Choremaster.
It' an interesting tractor and probably looks good pulling a sulky loaded with people around the fair grounds, I'm considering to scap out the model n form that other newer Briggs that my neighbour in town gave me. It has the internal 110 volt generator and ball bearing mains.
My Allis 720 has priority at the moment the Sundstrand hydro is acting up, need this tractor for snow duty as I'm retiring the 9020 and parting it out.
bc.gold
Back in 1948 the Choremaster was an expensive tractor.
link to page.
$148 in 1948 is worth $1,591.16 today, gold was worth $34.71 US a troy ounce in 1958, today 2020 one troy ounce of gold will set ya back a whopping $1948.00 US a troy ounce.
You would have come out financially better had you invested that $148.00 back in 1948 and purchased gold.
Edited by bcgold
