C_hasbeen
656 warn planetary gears worked to hard.
peter lena
C-Hasbeen ,my first question is what gear oil were you using ?  obvious cleaning  internally , hard to believe all those contact areas fractured and sheared off. possible hard impact and fracturing before your ownership? while everything can be replaced , i would suggest  matching up some extreme rated lube for those new parts . i personally have never had any breakage like that , good luck with your rebuild, pete
