peter lena 8,580 #26 Posted September 14, 2020 C-Hasbeen ,my first question is what gear oil were you using ? obvious cleaning internally , hard to believe all those contact areas fractured and sheared off. possible hard impact and fracturing before your ownership? while everything can be replaced , i would suggest matching up some extreme rated lube for those new parts . i personally have never had any breakage like that , good luck with your rebuild, pete Share this post Link to post Share on other sites
