Jon D 82 #1 Posted September 6, 2020 My father-in-law’s wheel horse stopped moving forward and rolled backwards into a tree today. The key broke off in hub and the hub has chunks missing from the keyway. I found a new hub on eBay and while I’m in there, I should fix the leaky axle seal. The tractor is a 12hp automatic with sunstrand transaxle. 1 1/8” axle. I’m having trouble finding a part number for the seal Share this post Link to post Share on other sites
jay bee 909 #2 Posted September 6, 2020 This might help you out. https://www.ebay.com/itm/TORO-Wheelhorse-Axle-Seals-6449-Set-of-2pc-FREE-SHIPPING/142042768245 And 2 2 Share this post Link to post Share on other sites
Jon D 82 #3 Posted September 6, 2020 Did they use the same seals for all 1 1/8” axles? Share this post Link to post Share on other sites
953 nut 55,769 #4 Posted September 6, 2020 9 hours ago, Jon D said: Did they use the same seals for all 1 1/8” axles? All Sundstrands and Eaton 1100 transaxles for use that same seal. I have used the supplier @jay bee suggested and they were a perfect fit. Will you be taking the transaxle apart to replace the bad axle or do you plan to repair it on the tractor? Look over this thread first. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,095 #5 Posted September 6, 2020 10 hours ago, Jon D said: Did they use the same seals for all 1 1/8” axles? No. Find a parts list for your model to determine the correct part number. Garry Share this post Link to post Share on other sites
Jon D 82 #6 Posted September 6, 2020 (edited) 2 hours ago, gwest_ca said: No. Find a parts list for your model to determine the correct part number. Garry I can’t find a parts list for it, it’s a 1973 (no name) I don’t know if it would be more like a charger or a c120 Edited September 6, 2020 by Jon D Share this post Link to post Share on other sites
Jon D 82 #7 Posted September 6, 2020 2 hours ago, 953 nut said: All Sundstrands and Eaton 1100 transaxles for use that same seal. I have used the supplier @jay bee suggested and they were a perfect fit. Will you be taking the transaxle apart to replace the bad axle or do you plan to repair it on the tractor? Look over this thread first. The axle isn’t in that bad of shape, the hub itself lost 2 chunks surrounding the keyway 1 Share this post Link to post Share on other sites
ebinmaine 68,330 #8 Posted September 6, 2020 Can you show a pic of the axle? A hub with the second set screw is a big help to prevent further issues. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,095 #9 Posted September 6, 2020 Garry 1 Share this post Link to post Share on other sites
Jon D 82 #10 Posted September 6, 2020 42 minutes ago, gwest_ca said: Garry Thank you! The seal listed is the same for sale up above 1 Share this post Link to post Share on other sites
Jon D 82 #11 Posted September 6, 2020 1 hour ago, ebinmaine said: Can you show a pic of the axle? A hub with the second set screw is a big help to prevent further issues. I’ll get a pic of the axle when I go back over there to take a file to it. Has some scoring around it but the keyway looks useable 1 Share this post Link to post Share on other sites
Jon D 82 #12 Posted September 6, 2020 Here’s a look at how bad the hub is, it was a real hassle getting it separated. The broken key was half in the groove and flipped up into broken hub 1 1 Share this post Link to post Share on other sites
pfrederi 17,866 #13 Posted September 6, 2020 Ouch. normally you could broach a new key way opposite the messed up one but if that gouging goes all the way round i am afraid you are looking for a new hub 2 Share this post Link to post Share on other sites
Jon D 82 #14 Posted September 6, 2020 2 minutes ago, pfrederi said: Ouch. normally you could broach a new key way opposite the messed up one but if that gouging goes all the way round i am afraid you are looking for a new hub I found a pair of hubs on eBay 2 Share this post Link to post Share on other sites
Jon D 82 #15 Posted September 6, 2020 Here is the axle, should clean up good with a file and sanding Share this post Link to post Share on other sites
ebinmaine 68,330 #16 Posted September 6, 2020 1 hour ago, Jon D said: Here is the axle, should clean up good with a file and sanding That'll clean up ok but the keyway is certainly a bit large. Share this post Link to post Share on other sites
lynnmor 7,353 #17 Posted September 6, 2020 That axle will work the key, if you use it be sure to add the second set screw and file a flat on the axle for the new set screw to contact. Check tightness regularly because a less than perfect fit will slowly work loose. If it were mine, I would make an effort to find a very good axle for reasonable cost. 1 Share this post Link to post Share on other sites
Jon D 82 #18 Posted September 6, 2020 33 minutes ago, lynnmor said: That axle will work the key, if you use it be sure to add the second set screw and file a flat on the axle for the new set screw to contact. Check tightness regularly because a less than perfect fit will slowly work loose. If it were mine, I would make an effort to find a very good axle for reasonable cost. As soon as I get new keys, I’ll check how tight it fits. If I have to, I can weld the corners and grind back in. Do you know what kind of steel was used on the axles? Share this post Link to post Share on other sites
lynnmor 7,353 #19 Posted September 7, 2020 I don’t know what steel was used but they did induction harden the area where the bearing runs. That tells me that welding might be problematic. If you do weld, don’t allow much heat to go inside and possibly soften the bearing surface and bearings. Share this post Link to post Share on other sites
Jon D 82 #20 Posted September 7, 2020 21 minutes ago, lynnmor said: I don’t know what steel was used but they did induction harden the area where the bearing runs. That tells me that welding might be problematic. If you do weld, don’t allow much heat to go inside and possibly soften the bearing surface and bearings. Locktite 660 might be a better route then. It’s made for this kind of problem Share this post Link to post Share on other sites
lynnmor 7,353 #21 Posted September 7, 2020 8 hours ago, Jon D said: Locktite 660 might be a better route then. It’s made for this kind of problem That should help with the cylindrical wear but not so much with the key wear. Keep the set screws tight and make them do the work, once the key takes the abuse, all bets are off. Share this post Link to post Share on other sites
Jon D 82 #22 Posted September 7, 2020 2 hours ago, lynnmor said: That should help with the cylindrical wear but not so much with the key wear. Keep the set screws tight and make them do the work, once the key takes the abuse, all bets are off. Locktite 660 is also marketed to fill the gap in a shaft, says to put some in the slot then press the key in and wipe off extra. Let dry and reassemble. I’ll also be adding at least one more set screw to that hub. This machine is only used to mow a small yard and along the driveway at my in-laws. Anything heavier of work, and I use my 520h or my f20 Share this post Link to post Share on other sites
ebinmaine 68,330 #23 Posted September 7, 2020 1 minute ago, Jon D said: adding at least one more set screw VERY good idea. It helps to add a flat surface to the axle where the 2nd screw will sit. Better grab for the screw. Also, the set screw will make a small ridge on the round of the axle. When the hub needs to come off again it helps by not creating that ridge Another flat where the jamb nut is on the hub. Helps keep things tighter, longer. 1 Share this post Link to post Share on other sites
lynnmor 7,353 #24 Posted September 7, 2020 I have used the Loctite 660, it forms what looks like a plastic shim to fill gaps. Unless a key has just a little wear, I wouldn't think that it would stay in place but it might be better than nothing. 1 Share this post Link to post Share on other sites
AMC RULES 37,134 #25 Posted September 7, 2020 LOCTITE 660 is a high strength retaining compound with good gap filling properties, ideal for repairing worn-out seats, keys, splines, bearings or tapers without remachining. LOCTITE® 660 is designed for the bonding of cylindrical fitting parts, particularly where bond gaps occurs without the need for remachining... 1 Share this post Link to post Share on other sites
