JustinW.73
856 Voltage Regulator
JustinW.73
Restoring my 856 and need a voltage regulator for it. I’ve only found one place to get a s/g mounted one and it wasn’t quite right. Anyone know where to get one?
peter lena
if you have the original # and type , you could try THE ROP SHOP, i have picked up a number of tractor related parts on their site. did a cross check and verified the part specifications , then looked it up on their site, good source, pete
pfrederi
Unless you are a stickler for restoration accuracy you can use any 12v saddle mount either 3 terminal or 4
  • Like 4
squonk
I just got this one for my 1075
Came from DB electrical
https://www.dbelectrical.com/products/generator-regulator-12-volt-four-terminal-two-unit-8040-6171.html
Edited by squonk
JustinW.73
34 minutes ago, squonk said:
That was the one I was looking at but was afraid of how much taller the bracket is and thought it would look weird.
wallfish
The mounting bracket is curved to fit on the generator. It doesn't stand off that high
953 nut
Looks just like the stock Delco Regulator to me.
SPINJIM
Try   I Save Tractors  .   Google them for their website.
JustinW.73
Not that part of the bracket. I ordered it so we’ll see.
