ebinmaine
Spray painting over powder coat?
ebinmaine
Any special prep we need to do to spray paint over powder coated wheels..?
Sarthurs01
just clean real good and scuff with a red scuff pad real good
Achto
:text-yeahthat: Red Scotchbrite pad or wet sand them with 500 grit sand paper. Degrease & spray.
SylvanLakeWH
“We”...? :confusion-confused: Paint department know about your use of the word “We”...? :ychain:
  • Haha 4
ebinmaine
I'll ... Uhhhhh..... Carry the wheels.. yeah.
  • Haha 4
RandyLittrell
I like to scuffpad with soapy water, kinda kills 2 birds with one stone so to speak. It will make your hands clean too!! Make sure you either blow out any water out of nooks and crannies or use a heat gun. Nothing will fire you up worse than water coming out of a place it shouldn't while your painting!!
Randy
ebinmaine
Randy
Before you spray the paint do you wash with acetone or just the soap is enough?
RandyLittrell
I always wipe down with a solvent right before painting. I like to use a final wash made for wiping down but anything that won't leave a residue will work.
As your better half knows, the better the prep, the better the paint job!! :D
Randy
WHNJ701
I always use mineral spirits as a final wipe/wash before primer
ebinmaine
Trina uses acetone
