ebinmaine 70,741 #1 Posted August 31, 2020 Any special prep we need to do to spray paint over powder coated wheels..? Share this post Link to post Share on other sites
Sarthurs01 918 #2 Posted August 31, 2020 15 minutes ago, ebinmaine said: Any special prep we need to do to spray paint over powder coated wheels..? just clean real good and scuff with a red scuff pad real good 2 Share this post Link to post Share on other sites
Achto 28,779 #3 Posted August 31, 2020 Red Scotchbrite pad or wet sand them with 500 grit sand paper. Degrease & spray. 3 Share this post Link to post Share on other sites
SylvanLakeWH 27,533 #4 Posted September 1, 2020 6 hours ago, ebinmaine said: Any special prep we need to do to spray paint over powder coated wheels..? “We”...? Paint department know about your use of the word “We”...? 4 Share this post Link to post Share on other sites
ebinmaine 70,741 #5 Posted September 1, 2020 15 minutes ago, SylvanLakeWH said: “We”...? Paint department know about your use of the word “We”...? I'll ... Uhhhhh..... Carry the wheels.. yeah. 4 Share this post Link to post Share on other sites
RandyLittrell 3,894 #6 Posted September 1, 2020 I like to scuffpad with soapy water, kinda kills 2 birds with one stone so to speak. It will make your hands clean too!! Make sure you either blow out any water out of nooks and crannies or use a heat gun. Nothing will fire you up worse than water coming out of a place it shouldn't while your painting!! Randy 1 Share this post Link to post Share on other sites
ebinmaine 70,741 #7 Posted September 1, 2020 4 minutes ago, RandyLittrell said: I like to scuffpad with soapy water, kinda kills 2 birds with one stone so to speak. It will make your hands clean too!! Make sure you either blow out any water out of nooks and crannies or use a heat gun. Nothing will fire you up worse than water coming out of a place it shouldn't while your painting!! Randy Before you spray the paint do you wash with acetone or just the soap is enough? Share this post Link to post Share on other sites
RandyLittrell 3,894 #8 Posted September 1, 2020 5 hours ago, ebinmaine said: Before you spray the paint do you wash with acetone or just the soap is enough? I always wipe down with a solvent right before painting. I like to use a final wash made for wiping down but anything that won't leave a residue will work. As your better half knows, the better the prep, the better the paint job!! Randy 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #9 Posted September 2, 2020 I always use mineral spirits as a final wipe/wash before primer 1 Share this post Link to post Share on other sites
ebinmaine 70,741 #10 Posted September 2, 2020 8 minutes ago, jabelman said: I always use mineral spirits as a final wipe/wash before primer Trina uses acetone Share this post Link to post Share on other sites
