The Tuul Crib
Correct springs for the parking brake and the brake on a charger
The Tuul Crib
I have been looking for these two springs for my charger. I've contacted A-to-Z tractors and I have Lincoln looking for them. I need the one for the parking brake and The other one that connects on the foot pedal brake. Any sources or where to find these springs would be helpful.
Thanx
Edited by The Tuul Crib
Achto
I took measurements to figure out the length and went to my local hardware store. Didn't necessarily score on my first or second attempt, but I did eventually win.
Edited by Achto
WHNJ701
My gosh, did you dump out your tool box on the floor!
  • Haha 1
ebinmaine
I need the pedal spring....
gt14rider
Motion control spring  1230
E-brake spring  9170
A-z shows 2 in stock
Pat's small engs (psep.biz) has 9170, call on 1230
Edited by gt14rider
clueless
I have the 1230 spring NOS, if you need one I'll mail it to you.
Chris
ebinmaine
E-brake spring  9170
when you say e brake spring are you talking about the one that pulls the brake pedal back to position?
gt14rider
Part #82  9170
Part# 109.    1230
The parts brake down is for a gt 14 but charger 12 should be the same.
ebinmaine
Looks like the same setup.
Not to hijack Randy's thread but the problem on my charger is that the brake pedal does not return to center..
I assume I'm missing some sort of spring.
First hydro I've had so I'm not familiar with the setup.
pfrederi
The spring that pulls the pedal back is the one in the bottom pic above hooks into #110  It is WH #1230
 Daveoman has an external fix in this pic.  Hooking the correct spring inside is a PIA  I have some springs I got from Mcmaster to use inside like 1230 you want one???
ebinmaine
I'd love one Paul. Thank you. I'll p.m. you my address. Shouldn't be as bad for me because the transmission is off at the moment.
pfrederi
Even so you are going to want some really long needle nose pliers  will send springs today or tomorrow
ebinmaine
Very nice.
If I don't have pliers long enough I guess I'll have to go tool shopping.
:D
Achto
The E-Brake spring is the one in this picture. It holds belt tension on when the brake is released. Also the lower rocker shaft holds the E-brake lever down when the brake is in the release position. When the brake is set the rocker shaft pivots back and the spring pulls up on the E-brake lever to set the brake inside the transmission.
ebinmaine
So mine is working properly.
Takes a fair amount of gumption to pull up or down on that lever and I'm wondering if there's some linkage worn somewhere. I'll check it out.
Achto
They usually don't move real easy. It's kind of a pull up & pivot back motion to get the two arms attached to the handle to swing correctly.
The Tuul Crib
Chris
Pm me! Thanx
The Tuul Crib
40 minutes ago, ebinmaine said:
Very nice.
:D
What you need is a long set of needle nose pliers.
pfrederi
  Check the bottom of the pin (Blue Circle.  The arm can wear a deep groove in it increasing the resistance/friction
gt14rider
Made some new pivot pins, going to try bronze bushing on e-brake side of pivot. Made bushings for rods. Welded eggshaped holes in side plates, added grommets to the holes
  • Excellent 2
oliver2-44
Looks good. It’s the little things like this repair that stretch out a restoration, but really makes the difference.
