David414
Grader Blade
David414
I need some assistance  please.
Will a wheel horse 40 inch mid mount grader blade and lift link from a c-100 and 1045 wheel horse,  fit a 1989, 414-8 wheel horse?
Thanks,108924742_10158073639693612_4481732863418181213_o.jpg.a1f8c7eb3e9e6d59d72119f74fa2630e.jpg
David414
Need some assistance please.
Does anyone know if a 40" grader blade used on a c-100 and 1045, will fit a 1989, 414-8 wheel horse?
Thanks,108924742_10158073639693612_4481732863418181213_o.jpg.c29db3a1c0766ffbba7932988728bd15.jpg110306774_10158073639728612_312351017975613974_o.jpg.f1d0636f4a6a3cb69a07ecdb74dfae94.jpg109706743_10158073639598612_7145211158290599603_o.jpg.b4141569c0b12b5843955147235b53bb.jpg
  • Excellent 1
gwest_ca
Yes it will.
Here is the order they were produced before they went to the pushed style
1965-1967 model MB-405 replaced by
1968 model 7-1111
1969-1974 model 7-1112
1974 model 7-1113
1975 model 7-1114
1976 model 67-40BM01
1977 model 77-40BM01
1978 model 87-40BM01
1979 model 97-40BM01
1980-1982 model 07-40BM01
Garry
ebinmaine
Yes sir. PINS right up.
Edited by ebinmaine
Minor repair of grammatical error on part of the writer
71_Bronco
9 minutes ago, ebinmaine said:
Yes sir. Bolts right up.
Well, technically there's no BOLTs, but we get the drift :ychain::laughing-rofl:
ebinmaine
Hahahahahaha
I went back and fixed it up.
David414
1 hour ago, gwest_ca said:
Yes it will.
1968 model 7-1111
1974 model 7-1113
1975 model 7-1114
Garry
Thanks for the info! What do you mean, before they went to the pushed style? Is there much difference between using a grader blade and the snow/dirt blade?
ebinmaine
David. The push style mounts to the back axle. It's a lot better used on a hydro tractor where you can control the lift a little easier.
Trina has a grader blade on her 867. There's a couple videos on my YouTube channel that show her using it.
The Mid Mount Grader is a drag style. The mount itself sits ahead of the blade.
JAinVA
That looks like the one I bought for my old c120.It should fit the 300/400 series.I had it on my 416h so you should be good to go.If you have not used one before they are quite handy.One word of caution is the lift handle can smack you on the knee on a manual trans if you hit a solid object
Edited by JAinVA
Pullstart
Yep, It’ll fit just fine!
  • Excellent 1
clueless
:text-yeahthat:
