Edgee
1967 857 Wheel Horse lawn tractor
Edgee
How do I grease the spindles on the mower deck
953 nut
Remove the cover and slap some grease on the gears.
gwest_ca
Tractorhead
@Edgee firstly :text-welcomewave: to :rs:
Thanks garry, for rework that Pict 👍
Be carefully when dealing with the grease nipples on the Spindles itself
too much pressure can harm or even damage your Spindle seal quickly.
Gently press - with not too much force until on undersite of the spindle grease is lurking out.
That‘s enough.
I found out a half stip on the grease press is enough on mine.
if it‘s regulary greased and the seal is intact, it will be even less than a complete stip on the grease press.
When removed the Cover internally i used 3 stip‘s and slaped it on the Gears.
The gear can also be serviced with the cover on, but i would suggesting remove it,
So you also be able to check the Gears itself for any wear, than remove first complete the old grease and slap new on.
