seven 202 #1 Posted August 18, 2020 Just found a nice Kohler magnum 18 twin cylinder and wondering how much it would take to put on one of my tractors . I have a c160 hydro a b80 a commando 8 . And a charger 12 hydro. Im leaning towards a gear shift just because I might use it for pulling some day Share this post Link to post Share on other sites
SPINJIM 1,981 #2 Posted August 18, 2020 You would have to relocate the battery to make room for a twin cylinder, and probably have to raise the hood to make room for the air cleaner. Has to at least be on a long frame. Wiring??? Kohler 18M is an excellent engine, if you can find a use for it. 1 Share this post Link to post Share on other sites
Achto 28,778 #3 Posted August 18, 2020 I think that the C160 would be the easiest fit for that engine. Share this post Link to post Share on other sites
AHS 1,491 #4 Posted August 18, 2020 They didn’t use the Kohler magnum twins? Or did they? Share this post Link to post Share on other sites
JCM 10,017 #5 Posted August 18, 2020 In 1987 the 418 had the 18 HP magnum twin and the 1986 420 had the 20 HP magnum twin. 1 1 Share this post Link to post Share on other sites
johnnymag3 2,559 #6 Posted August 18, 2020 If your tractors are original, and in good shape, and run well....I would not waste the time to retro-fit that engine to any of them....find a late 80's Tractor with a bad engine, and go from there...Way less headaches and keeps original machines ORIGINAL !! Just my opinion,... They are original only once and retain more Horse trading value when in that form john 2 1 1 Share this post Link to post Share on other sites
roadapples 6,983 #7 Posted August 18, 2020 5 hours ago, Achto said: I think that the C160 would be the easiest fit for that engine. Why mess with perfection... 2 4 2 Share this post Link to post Share on other sites
953 nut 57,904 #8 Posted August 18, 2020 Is the M-18 from a Wheel Horse, PTO could be a problem if not. There should be no problem with space since the K-Twins were used beginning in 1980 in the C-175 and it is the same basic engine. C-160 and B-80 should be an easy swap, Commando and Charger, not so much. To go from battery ignition to Magneto can be done by adding a "Kill Relay". 1 Share this post Link to post Share on other sites
AHS 1,491 #9 Posted August 19, 2020 17 hours ago, JCM said: In 1987 the 418 had the 18 HP magnum twin and the 1986 420 had the 20 HP magnum twin. Guess I will have to find one of those then!!😀 2 Share this post Link to post Share on other sites
pfrederi 18,333 #10 Posted August 19, 2020 Look up the spec number on the magnum on the Kohler website. Look at parts for crankcase. it will show if it has the needed thrust bearing to use with WH PTOs...most do not. 2 Share this post Link to post Share on other sites
seven 202 #11 Posted August 21, 2020 On 8/19/2020 at 9:05 AM, pfrederi said: Look up the spec number on the magnum on the Kohler website. Look at parts for crankcase. it will show if it has the needed thrust bearing to use with WH PTOs...most do not. Will do never new that? 1 Share this post Link to post Share on other sites
Dylan poucher 7 #12 Posted May 8, 2023 On 8/18/2020 at 12:14 PM, JCM said: In 1987 the 418 had the 18 HP magnum twin and the 1986 420 had the 20 HP magnum twin. Could you send/show me how to wire the engine if you could or if you even know Share this post Link to post Share on other sites
JCM 10,017 #13 Posted May 8, 2023 Wiring is not one of my strong points, sorry. Share this post Link to post Share on other sites
brians306 23 #14 Posted May 9, 2023 (edited) I just did that very thing. I will post pictures. battery under seat. im gonna have to cut 2 semicircles out of the lower edge off the hood for the stacks. The wiring is simple. Just power to the starter and a solenoid. I did use an adapter plate from a 520. just had to drill 2 holes on the right side Edited May 9, 2023 by brians306 Share this post Link to post Share on other sites
kpinnc 13,731 #15 Posted May 10, 2023 7 hours ago, brians306 said: im gonna have to cut 2 semicircles out of the lower edge off the hood for the stacks. Better to raise the front of the hood an inch. Just add a spacer between the hinge and hood. Share this post Link to post Share on other sites
brians306 23 #16 Posted May 18, 2023 On 5/9/2023 at 11:46 PM, kpinnc said: Better to raise the front of the hood an inch. Just add a spacer between the hinge and hood. I WOULD NEED TO RAISE THE STEERING TOWER AN INCH ALSO, HOW DO YOU SUGGEST THAT IS DONE? Share this post Link to post Share on other sites
kpinnc 13,731 #17 Posted May 18, 2023 1 hour ago, brians306 said: HOW DO YOU SUGGEST THAT IS DONE? I don't think adding an inch at the hood would necessarily mean the hoodstand will need the same. You can always mock it up with a block and see if it works for you. Wheel Horse had several models with raised hood pivots, and the tower stayed the same. 1 Share this post Link to post Share on other sites
