71_Bronco 1,072 #1 Posted August 15, 2020 in looking at new tires for my Lawn Ranger, I came across some that are only available in 4 ply, and some that are only available in 2 ply. I understand the difference between the 2 (construction, stiffness, puncture resistance, psi capability, weight rating). For a light-weight, fun putting tractor, is ply rating really an issue? Or should I just get the 4 ply tires for the extra strength just cause? 1 Share this post Link to post Share on other sites
ebinmaine 70,718 #2 Posted August 15, 2020 There are those who run 2 ply on purpose. Better ride. A little more forgiving. Easier to mount. Quite possibly better traction as well because of the tire being able to flex more. I run 4 ply on the Cinnamon Horse because it's our heavy load mover. Otherwise 2 would be fine. 2 Share this post Link to post Share on other sites
JAinVA 4,629 #3 Posted August 15, 2020 Eric covered all the reasons for the different uses well.The Lawn Rangers are relatively light compared to other horses.I would go with 2ply for most uses.JMHO,JAinVA 1 Share this post Link to post Share on other sites
RandyLittrell 3,894 #4 Posted August 15, 2020 2 ply will do you just fine, Eric covered the bases on reasons. Randy 1 Share this post Link to post Share on other sites
953 nut 57,885 #5 Posted August 15, 2020 9 hours ago, 71_Bronco said: some that are only available in 4 ply, and some that are only available in 2 ply. Two ply will do the job, but if you have a tread pattern you want and it is only available in four ply there is no reason to avoid it. 1 Share this post Link to post Share on other sites
pfrederi 18,328 #6 Posted August 15, 2020 The sidewall markings are sometimes two or four ply "Rated" If you cut one open they may or may not have 4 plies.... Share this post Link to post Share on other sites
71_Bronco 1,072 #7 Posted August 15, 2020 I think i made up my mind (finally) and have settled on the OTR "Lawn Trac" tires. They are only available in 18×8.50-8's and 4 ply rated. I know they arent as wide as the Carlisle "super lugs" (18×9.50-8), but i like the look of the tread better on these. Plus, compared to the stock tires (4.8-8 tires), these are going to be about 2 times as wide. I did read some reviews on amazon that some people said they are stiffer due to the 4 ply vs 2 ply, and that the ride was a bit more bumpy. Share this post Link to post Share on other sites
