71_Bronco 1,072 #1 Posted August 13, 2020 Going to pick up some Wheel Horse 12" weights today. I've seen them with and without notches cut for valve stems. The ones I'm going to get do NOT have the notch. How do these mount onto the wheels without the cut-out? Do they not seat down far enough into the rim to hit the stem? Or am I missing something here? Thanks! Share this post Link to post Share on other sites
squonk 40,703 #2 Posted August 13, 2020 The stems should be on the inside of the wheel 3 Share this post Link to post Share on other sites
71_Bronco 1,072 #3 Posted August 13, 2020 27 minutes ago, squonk said: The stems should be on the inside of the wheel Interesting. Never noticed that. I'm sure I've seen it, but never really stuck in my head that they were on the inside. Share this post Link to post Share on other sites
squonk 40,703 #4 Posted August 13, 2020 7 minutes ago, 71_Bronco said: Interesting. Never noticed that. I'm sure I've seen it, but never really stuck in my head that they were on the inside. The notched weights fit the D series which had the stem on the outside. Share this post Link to post Share on other sites
71_Bronco 1,072 #5 Posted August 13, 2020 (edited) Well I'll be darned, you guys are right. Stems are on the inside. Picked up the weights, and they came with a set of wheels, old tires, AND chains. How did I do? Edited August 13, 2020 by 71_Bronco 1 Share this post Link to post Share on other sites
