WheelhorseBob
520H Transmission oil change
WheelhorseBob
My first hydro.....So I read up on this topic and thought I had it covered. 5 quarts 10-30 oil, NAPA filter and pulled the bolt from the fender bracket to vent. (tank is off for cleaning) All was going well until I got maybe 3-3.5 quarts in. Then the oil level reached the bolt hole and started spewing out. In the threads I read that wasn't mentioned. I let it drain over night so I'm fairly sure all the oil was out. Question, how do I get the rest in?
troutbum70
If you did not raise the front of the tractor you would not get all the old out, of which unless you do a complete tear down its impossible to get it all out.
WheelhorseBob
So based on that logic it really isn’t a 5 quart change? I guess I assumed that if I drained it, changed the filter I would be able to add 5 quarts. Didn’t want to over think it but evidently I under thunk it?
squonk
3.5-4 qts is about the average oil change. There is oil trapped in the pump and lines as well.
tractormandash
Hi, my name is Jay and  I am brand new to the forum. I've got my first wheel horse. A 1995 416 h. I bought it as a winter unit. I live in Northern Michigan and have a 350 ft. driveway. I understand it has the same hydrostatic transmission as the 520h. My question is regarding oil. It says to use 10w30 or 40. The Easton manual says automatic transmission fluid and hydraulic oil can also be used. I was wondering what others have had the best luck with. I don't plan to cut grass with this machine, only single stage snow blow. If anyone has any of the bolt on wings I would be interested. Thank you for your help.
Jon D
I’ve been using 10w30 in my 520h. As for the wings, if you can’t find a set of them, they shouldn’t be too hard to make
R Scheer
I've been using Mobil 1 10w30.  It seems to work smoother with the full synthetic.
