upstate yank
UPDATE on the older tractor with the Briggs motor
upstate yank
well guys here i am again;asking if any one might know the year or even the motor size of this older wheel horse with the briggs motor ;i am sure it has been changed from a kohler ;but heck for 75 bucks i couldn't go wrong as it runs great after a new set of cables and a new electronic ignition system ;here are the numbers if any one might know
#1904-0206-4602-7309-2110
C-70388  thanks guys
Edited by upstate yank
ebinmaine
Maybe a snowblower engine?
Hydro transmission?
So 65 or newer.
Looks like the type of PTO from 65 to 67 or 8.
That's set up similar to what we did with Trina's Pony.
Hers is a Briggs 8 with a 3 speed.
gwest_ca
Here is a parts list for the engine.
https://www.partstree.com/models/190402-0646-xx-briggs-stratton-horizontal-engine/
If I remember correctly it was made September 21, 1973.
Those model numbers start with the approximate cubic inch displacement and 19 is oftem advertised as 8hp.
Engine operator manual
Engine service manual
Garry
upstate yank
Hydro transmission?
So 65 or newer.
thanks and yes that could be a snowblower motor who really knows what some will do no matter i am happy with it as it runs so nice and cuts the lawn ;and yep it is a hydro which i like more than the standard types
upstate yank
Those model numbers start with the approximate cubic inch displacement and 19 is often advertised as 8hp.
Garry
thanks so much as i thought it might be a 8 horse but i was confused with the year of the tractor but i am happy with it as it starts after the 2nd pull and mows very nice
Stepney
Looks like a 3 spoked steering wheel which generally tells me 1967-9. However it has stirrups instead of footplates and looks like a short frame?? Maybe an 875 with the wrong wheel?
Cant really tell the frame from a pic like that but the deck looks pretty tight there.
Is there a tag up under the dash?
EDIT it must be 1967 or later due to the hand brake being up near the fender. Older ones were down low.
So maybe a 1967 hydro of some sort? 1077?
Was there an 877 short frame that year?? I'm getting a bit forgetful.
Nothing really stops parts bodging but every long frame I've seen with an old style deck has an oversize driven pulley and uses the newer type PTO clutch. That had a foot pedal. Which goes along with the short frame/econohorse thought?
Edited by Stepney
953 nut
Yes there is an 877 and I would agree that the three spoke steering wheel and the hand brake bring me to that conclusion too. The Sundstrand should be # 3100077.
